Author Topic: Is it my points again?  (Read 1107 times)
Offline Dimitri13
  • 1974 CB550K
« on: August 27, 2012, 03:10:04 PM »
74 550K
I recently replaced my points/condensers. Sadly, they were Daiichi (made in Japan, not China), even though they were being sold by some other company (forgot which atm).
When gapping and timing them, I had to advance it nearly all the way to get it dialed in. I know that was an issue confirmed by HondaMan with the Chinese points, but I haven't heard anything about the Japanese points.
At first they were performing adequately. Only problem was ill-tuned carbs. Rode about 100 miles with them no problems. Well, on a ride yesterday, I started getting bad throttle response at low RPMs; stumbling off idle, can't get a smooth ride at lower throttle positions, and eventually started popping and farting and backfiring at WOT. Those were the same issues I had with my old points when they were gapped wrong and eventually just plain worn out.
I haven't been outside to check anything yet, and probably won't until later this afternoon.
I know someone is going to suggest electronic ignition. I don't have $300+ to spend on that right now, unless someone would like to sell me a used one.
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
Re: Is it my points again?
« Reply #1 on: August 27, 2012, 03:46:31 PM »
Dimitri ; Folks here will probably tell you to find TEC points. I'll probably get flamed for this but screw those 200/300 $$ electronic ignitions. Get a quality set of points (TEC) and if you want electric ignition get a "HondaMan" ignition. It keeps your points but only to trigger the ignition and if it Ever fails (so far I've only heard of 1 failing) just unplug it and plug you stock back in. Couple of minutes even on a hot motor and your back on the road. Not sure of the current price but one Hell of a repair/replacement gaurentee. Here is a link to his ignition thread, http://forums.sohc4.net/index.php?topic=67543.0 . Hope this helps.   ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
Offline Dimitri13
  • 1974 CB550K
« Reply #2 on: August 27, 2012, 04:41:45 PM »
I know that Toyo/TEC is the brand to get, but where do I get them? I know Honda sells them at about $100 a set...
Offline 2wheels
« Reply #3 on: August 27, 2012, 05:31:34 PM »
I go to the local Honda (car dealership)  I don't have a Honda bike dealer near me.
I give them the correct part number, they will not look up bike part numbers.
I am responsible for getting the part number correct.  They will not take the parts back.
I pay them.
2 days later I have my new points.  (60 dollars for a set of TEC) here in Canada
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline Mooshie
« Reply #4 on: August 27, 2012, 05:33:05 PM »
+1 on the Hondaman ignition. Super simple to revert back as needed. Great price and he responds immediately with questions or concerns.
I got mine on Ebay. Just make certain that when you look at the picture it says TEC on the plate.  You can see it clearly.  At my dealer it was $90 (it will say Toyo on their computer screen).  On Ebay I got mine for $70 shipped
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
bollingball
« Reply #5 on: August 27, 2012, 05:58:05 PM »
No way not a $100.00. $24. each plus tax. I just bought a set from the Honda shop. Wanted to start new with HondaMans ign. box.
Ken
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #6 on: August 27, 2012, 06:03:07 PM »
+2 for Hondaman's ignition module. However, it will not cure a faulty set of points. I have Daichi points - made in Japan - and Hondaman's ignition. On one occasion I came home running on two cylinders - very embarassing. The problem was a lose rivet connection on one set of points. I suggest that you disconnect the blue and yellow wires from the points and check the resistance across the points when they are closed using a digital multi meter on the ohms scale. The reading you get should be almost zero. Turn the crankshaft slowly and the multi meter should indicate a clean break as the points open. In my case I was getting erratic readings of 10 to 50 ohms across one set while they were closed. These points were new. When I removed them I found a loose rivet connection at one end. Tightened it up - no more problem. Pat
Regards
Pat from Australia
