Author Topic: stupid question fuel lines  (Read 6106 times)
Offline xsmooth69x
« on: August 28, 2012, 10:08:32 AM »
i cant seem to find on google any threads that mentions what are some good fuel lines
i remember i posted something about this and everyone gravitated to some specific brand
im using some clear blue crap fuel line i bought from a motorcycle shop. since im taking apart my carbs to move the needle clip might as well put some good quality line in
1975 CB550 (FINISHED?!?!?)
Re: stupid question fuel lines
« Reply #1 on: August 28, 2012, 10:21:00 AM »
Honda makes and sells fuel line
Offline Brantley
  • Drano
« Reply #2 on: August 28, 2012, 10:21:29 AM »
I use the 5.5mm Honda stuff. Kink resistant, lasts a long time, and you don't have to fight to get it on or off (or fight to keep it on, for that matter). Not cheap, but worth it. PN 95001-55003-60M.
Offline xsmooth69x
« Reply #3 on: August 28, 2012, 10:32:42 AM »
ya but there was like a specific aftermarket brand.
im not going to lie i just use regular 1/4 tubing i dont wanna pay for the exotic (here in the states) 5.5mm diameter or whatever line.
i just secure all the lines with zip ties they dont slip off.
Offline xsmooth69x
« Reply #4 on: August 28, 2012, 10:37:54 AM »
pro motion fuel lines any good.
im buying spark plugs and points from z1 and thats the fuel lines they have so if its decent or good it be a nice one stop shop and ill save some shipping $$$$$$$$$$
Offline lucky
« Reply #5 on: August 28, 2012, 11:08:38 AM »
Just remember that if it is a 1977-78 CB750 that the fuel lines
that distribute fuel to the accelerator nozzels have
brass restrictors hidden inside the black rubber hoses.
 Do not throw them away by accident.
« Last Edit: August 28, 2012, 11:53:42 AM by lucky »
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #6 on: August 28, 2012, 11:15:53 AM »
Not trying to be rude here, but you say you've asked this question before...So, go back and read through your posts until you find the thread...where you asked the same question before ;)
Or, you could try out that newfangled search function you don't seem too familiar with...(well, that part was rude ;D ;D )
3,850 results here: http://www.google.com/cse?cx=partner-pub-9323359806520211%3A1305160748&ie=UTF-8&q=fuel+line&siteurl=forums.sohc4.net%2Findex.php&ref=forums.sohc4.net%2Findex.php%3Faction%3Dunread&ss=1156j172712j9#gsc.tab=0&gsc.q=fuel%20line&gsc.page=1
« Last Edit: August 28, 2012, 11:20:12 AM by Greggo »
Offline Toxic
« Reply #7 on: August 28, 2012, 11:42:08 AM »
Sudco was the brand name that was highly recommended in the last thread I read on this subject.  It has a thin red line down the side
see here:  http://www.sudco.com/fuel.html#redstripe
As mentioned above the Honda product not only doesn't kink, it is also easier to route as it is a smaller overall diameter than the 1/4" stuff.
Get the right stuff, you will be glad you did
bollingball
« Reply #8 on: August 28, 2012, 12:10:08 PM »
1/4" no name hose with ZIP ties.  :o :o and you don't want to pay for the good stuff. FLAME ON. ;D ;D
« Reply #9 on: August 28, 2012, 12:18:27 PM »
Search ebay for Tygon, very happy with those.
Offline xsmooth69x
« Reply #10 on: August 28, 2012, 12:23:54 PM »
do u know how many posts that is?
ur result came up with 3850
i have wayyyy better things to do with my time then that sir!
i just needed a quick answer to a quick question.
you probably typed more in your response then if you wouldve been like brand A B C
Offline xsmooth69x
« Reply #11 on: August 28, 2012, 12:24:53 PM »
Good luck with that.
i have to use an excessive amount of force to pull them off..... its not like these lines are under presure and they sure wont vibrate off  :(
Offline xsmooth69x
« Reply #12 on: August 28, 2012, 12:26:06 PM »
i have a 1972 cb750 i havent gotten around to yet. i was talking about my cb550
does the 1972 have these hidden restircters?
Offline xsmooth69x
« Reply #13 on: August 28, 2012, 12:26:46 PM »
+1 to you it was tygon i remember that name
but on a side note.... promotion any good?
Offline Toxic
« Reply #14 on: August 28, 2012, 12:56:02 PM »
Might be just me but I couldn't find the Tygon in a 5.5mm dia.
The Sudco in the link I posted is available in 5.5mm and to my fellow Canadians that stumble across this thread, the Sudco is available from British Cycle Supply in Wolfville N.S.
Cheers
Offline Brantley
  • Drano
« Reply #15 on: August 28, 2012, 01:09:43 PM »
Like post 7 and counting times regarding fuel lines?
« Reply #16 on: August 28, 2012, 01:19:14 PM »
"i have wayyyy better things to do with my time then that sir!"
I think the point is that the Google Custom Search works very well. Just give it a phrase to look for. Even though it will find thousands, your answer will almost surely lie in the first few. That is the case with a search on "fuel line". everything in this current thread was disclosed/discussed in the first few of the search.
Don't get me wrong, I'm perfectly fine with revisiting a subject. At times something new or previously missed comes to light.
My point is simply the Google Custom Search works very well, if needed.
Offline vames
« Reply #17 on: August 28, 2012, 02:06:41 PM »
Motion pro line on Z1 site comes in ID of 3/16" 1/4" and 5/16".
Those sizes translate into 4.76mm (too small), 6.35mm (too big) and 7.94mm (wayyy too big).
None are the 5.5mm size that your bike needs.
You could probably squeeze the 3/16 line on there, but it's gonna split eventually, exactly when you don't want it to.
Answer is NO those won't work.
« Last Edit: August 28, 2012, 02:13:31 PM by vames »
Offline aperry
« Reply #18 on: August 28, 2012, 02:26:31 PM »
I'm running 3/16.  It's super tight and if you put it all the way up the nipples then it's nearly impossible to remove without cutting.  In fact, most of the time the petcock nipple pops out before the fuel line.  Yup, I put those two words in the same sentence.  So funny.
Looks like you can get a meter of black 5.5" fuel line on ebay for about $15 shipped.   I'd love to know if you can get it in a clear (or translucent).  I've enjoyed looking at he fuel in my lines!
Aaron
CB750K3 with F1 frame/swingarm
« Reply #19 on: August 28, 2012, 04:39:54 PM »
Aaron
I've really looked and never found 5.5 in clear. I too like looking at the fuel. I found a 1/4 in clear with gold braid in it. Don't know where though, just have it in my scrap box from 100 years ago. It fits tight.
Which goes to the point. Some people will find loose 3/16 and others tight 1/4 that suits them well. Just manufacturing tolerances.
But overall, those sizes they are too tight or too loose.
Offline aperry
« Reply #20 on: August 28, 2012, 04:57:20 PM »
I bought some 1/4 braided too, but it needs clamps to stay sealed.  I have the petcock style that has two fuel outlets and using clamps made it really difficult to deal with.  It was also a really tight fit through the holes in the carb mount plate.
At some point when things are running well and I trust the bike a little better then I'll probably just buy some black 5.5.  For now it's clear 3/16.
Aaron
Sent from my iPad using Tapatalk HD
« Reply #21 on: August 28, 2012, 05:00:05 PM »
Aaron
I cheated and have the single spigot petcock and Mikunis, so the routing is different.
Offline aperry
« Reply #22 on: August 28, 2012, 05:11:56 PM »
Aaron
Very nice.  I have a growing list of improvements to work on over the winter.  Fuel line was just added!
« Reply #23 on: August 28, 2012, 06:35:49 PM »
I think I run 3/16"Tygons  on my carburetors.   I can pull them off and put them back on and it still seals.  Much better than the nylon I had before.
Offline Teatimetim
« Reply #24 on: August 29, 2012, 08:16:50 AM »
Bikes I own:
1974 CB550K
1971 CB450
