Author Topic: long commute limp wrist :(  (Read 8730 times)
Re: long commute limp wrist :(
« Reply #25 on: August 28, 2012, 06:23:32 PM »
then you are a fool.
Coming from someone who suggests using the tension adjustment.....and you think I'm the fool??????
FWIW, I didn't pay that much, not that I wouldn't if I was planning on more long touring days.
It works well, on/off with the flick of the thumb, doesn't slip or drag on the throttle tube, doesn't look like an add on, is durable, and not susceptible to weathering from sun and ozone. That might be why it is popular on the touring and sport touring forums?
I have also used Cramp Buster (helps), Vista Cruise (slipped slowly on throttle tube), Throttlemeister (didn't like the twist activation), Brake Away (excellent), and Audiovox (excellent if installed properly).
If $ is the prime consideration, you can add a set of bar end weights to your bars, and simply use a fat O-ring to roll in or out of the space between the weight and the throttle tube. It works also.
Sometimes you get what you pay for.
I use the VistaCruise on my FJR, works fine. But i would use that eyecandy drag you're showing in a minute. Foolish it may be.
These are just big toys, and buying candy for our babies is all part of the experience. $125 is fair for what it is, and I'd pay it in a minute, may have to, for all the reasons you mention and it just looks neat!
Offline brewsky
« Reply #26 on: August 28, 2012, 06:32:19 PM »
I could never get the Vista to hold tight enough not to slip on my CB750. I think maybe the return spring is stiffer on the K8? I even scuffed up the throttle tube itself as well as the ID of the Vista. It worked, just not for long.
The Madco has really gone up in 5 years....I think it was in the $60 range when I got it, but I can't really remember.
The Brake Away is actually better in function, as it releases when you tap the brake lever, but it is also more expensive.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline CrankyOldGuy
  • Wish I was a
« Reply #27 on: August 28, 2012, 08:16:10 PM »
i use the tension adjuster built into my throttle assembly,works pretty good.I know I am not supposed to,but hey rules are meant to be broken.
Here I am hijacking another thread ... but what the heck ... I got to know.
Just wondering if the Honda 750k1 Owner's manual is incorrect.  On page 52, Item 3 it states "The adjustment of the throttle grip damping movement can be set to suit suit the rider's preference.  The throttle adjustment is made by the throttle grip adjustment bolt.  Turning the adjust bolt in the grip will tighten the grip movement"  Just wondering because I have used this quite successfully in the past on long trips.
Harry O.
750 K1 Original Owner
Offline bikerbart
« Reply #28 on: August 28, 2012, 08:18:34 PM »
I was talking about the price,also when I said I used the tension adjust I also said I shouldnt.
Offline 750K
« Reply #29 on: August 28, 2012, 10:35:49 PM »
this is all very valid exept......
1) i have clip on bars
2) i have the old school foam grips and grip tape on them to look cool  8)
clip ons with no rear sets = back comfort gone
big foam grips = hand comfort gone
you might think this is crazy!!! why would i put or do something like this to myself and my bike?!?! well thats because im stupid and looks are more important to me. do i deserve it ya. but i just want something that might ease my idiocracy on ergonomics
In the words of Chopper Ried.
Harden the #$%* up, hahaha.
77 Cb750, 78 Kz1000
Offline xsmooth69x
« Reply #30 on: August 29, 2012, 11:55:08 AM »
1975 CB550 (FINISHED?!?!?)
Offline Rgconner
« Reply #31 on: August 29, 2012, 12:11:14 PM »
I use the gocruise. Cheap, works, can move it to the Vespa if I want to...
1975 CB550K aka "Grease Monkey"
Offline liPPy
  • 1978 cb750k
« Reply #32 on: August 29, 2012, 12:33:48 PM »
Where I'm from "having a limp wrist" is a euphemism for being gay, not that there's anything wrong with that.
Offline bikerbart
« Reply #33 on: August 29, 2012, 01:06:11 PM »
I'm thuper,thanks for asking ;D ;D ;D ;D
Offline nccb
  • 1974 CB750 Four
« Reply #34 on: August 29, 2012, 07:21:44 PM »
i have heard this as well and honestly never understood the joke ??? is it from a 70s flick or something.
Offline wvshooter
« Reply #35 on: August 29, 2012, 09:26:31 PM »
I don't know if your 550 is like my '74 750 but the 750 throttle had a way too strong throttle return spring. The spring sits down in the middle of the carb bank. After about an hour it was really painful to keep the throttle twisted open. I put up with it for a while but finally decided to remove the spring.
Now my throttle moves freely in either direction.
Offline shinyribs
« Reply #36 on: August 29, 2012, 10:21:20 PM »
Same here. Return springs on the 750 are ridiculous . Tossed mine and glad I did. Crampbuster works real good for $6-8. Throttle locks are nice,but these bikes dont have the power to pull  hills on the highway without giving them more throttle.
Regardless, an hour and fifteen minutes is more than some guys ride all week. I commend you for actually putting miles on your bike. You'll have to get used to it to a degree. Keep on rockin' man.
75 minutes with clip ons and rear sets is no easy feat. I dont care what anyone says
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
Offline Magilla
  • My bike: 1976 CB750F
« Reply #37 on: August 30, 2012, 03:36:35 AM »
There is a very simple clip on plastic piece that will help you.  It allows you to rest the right side of your palm on it as you ride.  This allows you to not rely on your grip as much.
No bottoms to push.  Not complex/ugly set up.  Cost is cheap.  And when you don't want it on, it's a quick snap to take it off.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
« Reply #38 on: August 30, 2012, 05:51:45 AM »
Google it. It goes back to Roman times, simple reference to feminine gestures v masculine gestures.
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #39 on: August 30, 2012, 06:01:11 AM »
And the "not that there's anything wrong with that" part is from a famous Seinfield episode.
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline fmctm1sw
« Reply #40 on: August 30, 2012, 06:21:31 AM »
The CX500 I picked up had a gizmo on there like that.  It slipped onto the throttle tube and had a little lever on it you moved with your thumb.  I took it off.
edit:  It's exactly this:  http://www.ebay.com/itm/NEW-Sound-Off-Recreational-MCVICO-Vista-Cruise-Control-/370552322130?pt=Motorcycles_Parts_Accessories&hash=item5646a3b852&vxp=mtr
« Last Edit: August 30, 2012, 06:24:21 AM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline ChuckG750f1
« Reply #41 on: August 30, 2012, 06:54:20 AM »
Sounds like the same thing my 750 had on it.  I took it off too.
- John Wayne
1976 CB750 f1
Offline LoVel
  • Yes, I remember your mother well. She was quite the
  • 1972 CB500 four
« Reply #42 on: August 30, 2012, 07:52:48 AM »
I would like to give a 4th or 5th nod to the cramp buster.  Simple and works great.  You can open up your hand and just leave your palm on the flat part to hold the throttle open.
I'm an individual,  just like everyone else.
Offline xsmooth69x
« Reply #43 on: August 30, 2012, 08:45:23 AM »
.......  clip on and NO rear sets so its worse lol
I thought ur bike is supposed to put  miles on lol. From what ive seen these bikes are super reliable and strong even if ur bike illiterate
Ill order the cramp busters
Offline 750K
« Reply #44 on: August 30, 2012, 09:12:13 AM »
Just start doing lots of push ups, haha
77 Cb750, 78 Kz1000
