Author Topic: College build '78 cb550 cafe. Creating the Old  (Read 28406 times)
Offline Strangexj86
Re: College build '78 cb550 cafe. Creating the Old
« Reply #100 on: March 18, 2013, 11:13:06 AM »
FOund an upholstery shop a few miles away that will stitch up my seat the way I want. Basically, I wajt it to be like the cb750 brats on bike exif,  just smaller.
Picked up some faux leather from michael's that is exatly like what I had imagined.
I'll be making the rear portion of the seat later today.
1989 BMW e30 s52 turbo (illegitimate love child)
1989 Mercedes 420SEL (baby)
1978 cb550four (In progress)
http://www.r3vlimited.com/board/showthread.php?t=192128http://www.r3vlimited.com/board/showthread.php?t=215540
Offline laminaytrap
    • Satchealous Garage
« Reply #101 on: March 18, 2013, 11:18:39 AM »
That seat looks a little slim comfort-wise but it's coming along great. Are you putting a boss in the hump for the tailight? or is it going below?
Offline Strangexj86
« Reply #102 on: March 18, 2013, 11:49:18 AM »
Oh that is just the first layer of foam. I've already added a second layer and it is way thicker and comfortable now. I had the spray adhesion to set over night.
What do you mean by boss?
Offline laminaytrap
« Reply #103 on: March 18, 2013, 11:52:31 AM »
good to hear!
i mean like this
Offline Strangexj86
« Reply #104 on: March 18, 2013, 11:58:11 AM »
I'm pretty sure I'll be unstalling two of these side by side in the hump like you're talking about. I dont have any space below the hoop.
They're only 2" wide and less than an inch deep, which will work great for under then hump.
On the fence about using turn signals or not.
Offline laminaytrap
« Reply #105 on: March 18, 2013, 12:01:12 PM »
oh yeah i remember you saying that... you could always do this  ;)
Untitled by bailey_james62@ymail.com, on Flickr
Offline Strangexj86
« Reply #106 on: March 18, 2013, 12:34:39 PM »
I actually looked into doing something like that, but I dont want to cut up the rear hoop at all, and I really like the looks of two circle lights in the hump. And the RCW laws in Washington make it Illegal to have the indicators and brake light so close together. They need to have a few inches inbetween each. thanks for the suggestion though.
Offline Strangexj86
« Reply #107 on: March 18, 2013, 03:57:47 PM »
This is the style seat I will be having stitched up.
And this is pretty similar to how I want my paint job to look like. "Faux Patina" Going with the rat rod style I guess.
« Last Edit: March 18, 2013, 04:01:55 PM by Strangexj86 »
Offline laminaytrap
« Reply #108 on: March 19, 2013, 08:06:38 AM »
mmmm tasty...
Offline Strangexj86
« Reply #109 on: March 25, 2013, 06:02:50 PM »
Got my rearsets today! These things look great. can't wait to install them today.
Made some reinforcement plates with a plasma cutter.
painted my caliper and brake lines just to freshen them up a bit.
THought you guys might like the new ignition system
Then I tried out some different color schemes on the tank. Stripped the oem stickers off too.
« Last Edit: March 25, 2013, 06:04:46 PM by Strangexj86 »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #110 on: March 26, 2013, 10:30:32 AM »
soo... I was planning on leaving today for a spring break ski trip but my roommate decided the brake pads on his car needed to be replaced first. Long story short, once gouged caliper cylinder, and one stripped bleeder screw, and we're stuck. Tried tapping with a bigger size, yada yada yada no success. Gonna try a different McGuyver style fix tomorrow.
Anyways, the car setback gave me some time to work on the bike. So I shaped the seat hump. I tried copying the lines of the tank.
how did your friend gouge a caliper cylinder? I've replaced brake pads on at least 20 different cars over the past 30 years and never once needed to remove a piston or crack open the bleeder screw.
Offline Bankerdanny
« Reply #111 on: March 26, 2013, 10:39:58 AM »
Oh, and the build looks great. LOVE the carbs.
Offline SF
  • I burn gas very well
« Reply #112 on: March 26, 2013, 11:39:32 AM »
kool build man. i like it
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline Strangexj86
« Reply #113 on: March 26, 2013, 12:01:20 PM »
[/quote]
[/quote]
it was on a VW Passat and I guess when you compress the caliper piston to get enough space to put the new pads in and get it on the rotor, the cylinder piston has to "spin/twist" as you compress it. dumbest design ever! Crazy story actually too! The guy that ended up replacing the calipers (VW and Audi specialist) twisted the brake line when he reinstalled it, so 4 hours later going down a mountain pass the brakes went out. The brake line had rubbed up against the tire and blew hole in it.
Offline Strangexj86
« Reply #114 on: March 26, 2013, 12:02:58 PM »
thanks! I'm having a bit of trouble with the rear sets right now. I'm not a fan of the style of rod ends that came with it. I thought i was going to get the eyelet style ones.
Offline MJL
  • Don't listen to me, I'm no
« Reply #115 on: March 27, 2013, 06:37:31 AM »
Please dont use these. With all the detail so far it would be a shame to use lights like this.
BTW, I've never seen these lights in a 2 inch size that are dual filament.
Offline Bankerdanny
« Reply #116 on: March 27, 2013, 09:46:56 AM »
Ah. I have a Jetta, so I know what you are talking about. You need a special tool to rotate the piston easily while you compress it. Most of the chain parts stores have one that they will loan you. My old Saab 900 was the same way.
Offline CB350 Four
  • CB350F, Hercules MK3M, Hercules MK3M Cafe racer
    • Hercules Cafe-project
« Reply #117 on: March 27, 2013, 12:06:02 PM »
I used an old bicycle light and fitted a very bright LED.
I really like how it follows the line.
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #118 on: March 27, 2013, 01:10:29 PM »
Looking good!  Love the carbs, and where did you get that rear set??
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
Offline bjbuchanan
« Reply #119 on: March 27, 2013, 02:12:02 PM »
Another this g with the cheapue round one is that the rubber is the mount. You have to then put the light in thru the backside which means you need a solid flat mount. The lights blow imo
Offline Frankensteins Bride
« Reply #120 on: March 27, 2013, 02:54:55 PM »
I really like the line of your bike. :) I love that rear end too.. hehe
Working on: 78 Cb750k
Waiting for arrival: 73 Cb750
Frankensteins Wolf
Offline Strangexj86
« Reply #121 on: March 28, 2013, 01:39:20 PM »
Yeah i was thinking the same thing after i actually held one of these lights. It's just too ugly. Thanks for the suggestion.
now that looks great! I really like what you did there. Getting me thinking of how i can use some other stuff for the brake. hmm... pondering ideas now, thanks.
thanks. I'm happy with the carbs too. copper is awesome. I got the rearsets from oldschoolspeed.com. its just one guy, and hes on dotheton forum under the name durgam_k
Offline Strangexj86
« Reply #122 on: March 29, 2013, 12:32:32 PM »
finished painting the rear wheel. I copper plated the sprocket too. I know you cant really see it when the chain is on it, but i wanted to do it anyways.
Offline Strangexj86
« Reply #123 on: March 31, 2013, 03:51:35 AM »
here's the paintjob. It's not exactly what I was going for because I couldn't find the right colors so i improvised a little. Worst case scenario, if i don't dig it after a while I can just spray over it no problem.
the color under the orangle looks blue in thsese pics, but it's actually a dark black.
« Last Edit: March 31, 2013, 03:54:58 AM by Strangexj86 »
Offline laminaytrap
« Reply #124 on: April 01, 2013, 07:41:39 AM »
Gonna have to be honest...
Looks like primer on bondo...
I think a couple different shades of gray/black sanded through in that style might look nice, then maybe a bit of orange/gold pearl in the clear to give it some colour.
Good effort though, the colour is just reminiscent of so many bodywork repairs.
Jon
