The SOHC/4 World Tour is in under way.
couple of points:1) if you keep those mini gauges the tach won't be accurate. As far as I know there isn't anybody making a mini tach in the appropriate ratio for the 550/500/400/350F and twins. If you don't believe me put a dwell meter on it and check it yourself.2) you needed to have the swingarm in place with the fully assembled rear wheel/tire and the shocks (minus the springs so you can compress them to the bumpstop) to check for clearance when you were fabbing up your hoop. I would check your clearance before you paint the frame.
I love your Twin Peaks themed garage
Subscribed.
Love the bar end mirrors. Where did you get them from?
very nice...you got skills.
