Author Topic: CB400F intake manifold installation tip  (Read 5124 times)
oldbob
« on: August 31, 2012, 07:50:05 AM »
Every time after I have crammed the plastic intake manifold between the carbs and the airbox, I wrestle with getting all of the "snorkels" fully seated. I just tried a different approach. I pushed an uninflated bicycle inner tube into the manifold from the airbox, and inflated the tube until everything was seated. I tightened the clamps and then deflated the tube.
If I had thought of this before the wrestling match of getting the manifold into place, I would have planted the uninflated tube inside of the manifold first. Shoving it in from the airbox is not particularly easy.
Bob
Offline vames
Re: CB400F intake manifold installation tip
« Reply #1 on: August 31, 2012, 08:52:58 AM »
I don't at all get what you're talking about, but I'm intrigued.
You're somehow using a bicycle tube to line up and attach the rubbers between the airbox and the carbs?
Can you provide a picture and/or a hand-drawn diagram of what you're doing?
Offline Teatimetim
« Reply #2 on: August 31, 2012, 08:59:48 AM »
yes pictures
Bikes I own:
1974 CB550K
1971 CB450
oldbob
« Reply #3 on: August 31, 2012, 10:11:58 AM »
Looking at the line drawing (view from above), the black is the airbox and its five snorkels. The red is a folded bicycle inner tube.
I crammed as much into the airbox as I could while leaving the stem outside.
After inflating the tube, the front side of the air box was pushed toward the carbs while the back side was pushed toward the airbox, seating all five snorkels.
Bob
Offline craywm
« Reply #4 on: August 31, 2012, 11:47:09 AM »
brilliant! no more leaks for me on my 350, though ill use a smaller tire. Thanks for the tip oldbob!!
Offline vames
« Reply #5 on: August 31, 2012, 12:05:02 PM »
Very cool. Thanks for this. It should definitely be added to the Tips & Tricks section. Not sure how to do that, though.
Offline -CB-Jamie-
« Reply #6 on: August 31, 2012, 02:49:28 PM »
That's ingenious man I have struggled trying to get the manifold back on fully so many times, thanks for the tip you should definitely get this added to the tips and tricks section.
72 CB350/4
76 CB400/4 CB400f "Project Resurrection"
77 CB550/4 1977 CB550 Yet Another Cafe
77 cb200
09 cbf600
Offline RickB
    • Pop Magazine
« Reply #7 on: August 31, 2012, 05:51:01 PM »
Ingenious! I've always struggled with the inner two snorkels and have had to use the heat gun to massage them in. This would make the job way easier.
Offline phil71
« Reply #8 on: August 31, 2012, 06:03:29 PM »
i honestly cannot believe that worked. if you had stiff, s#!tty old boots i'd bet on the airbox busting open before those boots seat.
Offline camelman
  • Man... Myth... Legend
« Reply #9 on: September 01, 2012, 12:48:42 AM »
Great idea!!!  Thanks for sharing.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline MoMo
  • Ride like you're invisible
« Reply #10 on: September 01, 2012, 03:13:29 AM »
Great idea for bringing the inner boots up so they can be properly seated...Larry
Offline Kwality
« Reply #11 on: September 02, 2012, 08:31:33 PM »
Gold!  I'll be trying this one.
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
« Reply #12 on: September 02, 2012, 09:48:34 PM »
Ah Crap ! First let me say Excellent tip !!! I may be going through the same thing in the near future. And putting this in "Tips and Tricks" like "vames" suggested is a great idea as well ! Now here is my problem (Sorry, not being an A**) , the item you are calling "intake manifold" is incorrect. Correct me if I'm wrong, the intake manifold is between the carbs and the head. David Silver Spares calls piece you're talikng about an "Air filter box manifold chamber". "hondapartshouse" calls it "Chamber Assembly" . The only reason I bring this up is if it is to be saved somewhere it Needs to be saved with Correct Identification so it can be found when looking for that Item.  Kinda like trying to find a certian "wheel" when you're looking for a "tire".     Like I said Excellent Tip that should be saved !!! Just save it correctly (in the title) so it can be easier to find.   ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
oldbob
« Reply #13 on: September 03, 2012, 07:21:09 AM »
Good point, Cougar. My terminology was sloppy, particularly in the last post where I called the air filter box manifold chamber the "airbox."
Bob
« Last Edit: September 03, 2012, 08:41:13 AM by oldbob »
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #14 on: September 03, 2012, 01:04:10 PM »
I know it as a 'plenum chamber'
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline cougar
« Reply #15 on: September 03, 2012, 08:54:26 PM »
oldbob ; Yes, please don't take my "correction" comment ! I am in no way trying to slight the posting/idea ! It is a Great one !! Just for archiving, well you know what I'm sayin' . Again Great Tip !! Keep up the Good work !   ...cougar...
oldbob
« Reply #16 on: September 04, 2012, 06:08:04 PM »
It's officially in Tips & Tricks. http://forums.sohc4.net/index.php?topic=112310.0
Thanks for the positive feedback.
Bob
Offline Redline it
  • thread killer
« Reply #17 on: August 25, 2023, 10:58:28 PM »
that is pretty cool idea, i usually snug the center 2 to where they just drag a bit, and have to poke a large crescent wrench or a piece of wood to push in 2 and 3, they're always the ones lagging. that plenum or whatever it is, must get warped. it's always a little stubborn spot.
Offline Nurse Julie
« Reply #18 on: August 26, 2023, 02:08:47 PM »
Using the inner tube method is quite common over the pond here in UK. I've never had to resort to it myself but those I know that have used it laugh at the rest of us for struggling and swearing.
« Last Edit: August 26, 2023, 02:10:35 PM by Nurse Julie »
Trust me I'm a Nurse, I promise it won't hurt....much
