Author Topic: Change Relay Schematic  (Read 2231 times)
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« on: August 31, 2012, 09:59:30 AM »
I've always struggled with the wiring diagram on this subsystem, so I thought I'd take the time to draw it out in as a schematic.  The attached file is for a 1976 CB750A.  I believe that I've figured out the 77/78 - but I'm not going to post until I confirm (it appears that the Service Manual has some errors - as well as the schematic).
Hope this helps somebody - other than just me.
Also - in case you may need it, here is how and where to move two wires to convert a 77/78 bike to 76 wiring - in case the speed warning unit is acting up - or otherwise doesn't work:
http://forums.sohc4.net/index.php?topic=112231.0
« Last Edit: January 08, 2013, 05:50:21 AM by kandrtech »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
