Last night I sprayed some WD-40 on the slides to see if that would smooth out the operation. It did, but only a very little bit. It's still very rough as the slides go up and down. If I open it up all the way, it siezes at the top and has to be forced back down. I did remove the link arm from the throttle shaft, but did not disassemble anything on the throttle shaft (slide). I left the jet needle and slide areas alone as that looked good.
As requested, here are some pics.
#1 shows from top view down inside the carbs. I don't notice anything wrong.
#2 Shows from back side.Again, everything looks good to me.
#3 shows where the idle adjustment screw stops. It's about 1/8" - 1/4" from the lever on the bar and does not touch it. It did before I disassembled, but only barely.
I can take more pics if needed.
Any suggestions???
