Author Topic: Motion Pro tools. Any must haves?  (Read 1064 times)
Offline fmctm1sw
« on: September 02, 2012, 07:02:18 PM »
Found a local place here that says they sell most of Motion Pro's tools.  Is there anything you have from them that's a "can't live without?"
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #1 on: September 02, 2012, 08:14:06 PM »
Tappet feeler gauges
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline CycleRanger
  • No comment about being an
Re: Motion Pro tools. Any must haves?
« Reply #2 on: September 02, 2012, 09:36:54 PM »
Tappet wrenches, clutch bolt socket, carb sync gauges.
Offline srbakker
  • Spam & Eggs
« Reply #3 on: September 02, 2012, 10:31:18 PM »
I like the little cable lube tool, and I'll second the carb sync gauge.
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
« Reply #4 on: September 03, 2012, 05:28:37 AM »
Tire spoons for sure, maybe not the best out there but @5 bucks a piece, there is no need to use screwdriver anymore.
Offline toytuff
  • "watching the pinheads"
« Reply #5 on: September 03, 2012, 05:46:07 AM »
I picked up a valve shim tool and spoke wrench as well as feelers. Carb sync tool also.
Have used them all.  ;)
tt
Offline fmctm1sw
« Reply #6 on: September 03, 2012, 09:15:51 PM »
Well this sucks.  They were closed today (labor day)...    :(
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #7 on: September 04, 2012, 07:30:43 AM »
1 - carb sync tool, you know, the long one with the screwdriver running through the middle to make vac sync adjustments.
2- 5mm carb vac synch port adapters.  the brass ones with paper washers and rubber caps.  no more fishing screws off a hot engine.
3 - another vote for the  tappet wrenches and feeler gauges
