Author Topic: CB 400F Carb adjustment and swingarm  (Read 487 times)
Offline jonboycox
« on: September 03, 2012, 06:28:42 PM »
Hi, I have a 1977 CB400F that has been on the road for the first time in 20 years this summer. It is running well (with much help from this forum) but seems to be rich(?). The airbox and filter are stock, as well as the header. I am running a MAC muffler. It has a Dyna electronic ignition. The first thing I did about 1 1/2 years ago was to have the carbs cleaned and rebuilt by a reputable and Honda specific shop in the area. I adjusted the valves to proper tolerances, the timing is dialed in and the battery is in good shape. Initially I was fouling plugs after 100 miles or so. I opened the air screws to 1 3/4 turns and have stopped fouling plugs. The plugs are tan to light grey at the electrode, but black around the outer edge.  I seem to getting 45-50 mpg. It is hard to know how the performance is as this is the first and only bike I have worked on/rode. This has been an amazing process to breath life into this old machine and I am grateful to be on the road and down to fine tuning. It initially had 8800 miles, but after a dry summer I am sitting at 10500. Should I look at the carbs? It was the one thing I did not personally do. I have read dirty emulsifiers could be the issue. After much searching I have not found much specific to the CB400F carb, and how and when to adjust needle height.
  Also on a different note, I have had to straighten the swing arm that came on the bike as well as one from a bin of parts that I bought. Both where relatively east to straighten, but I am left wondering if this is a weak point on these bikes. Could the torque of the motor over time twist the "legs" of the swingarm, or is it really only an impact that would do that? Anyway, the wheels are now sitting plumb to one another and the bike, which makes the ride a lot more neutral. I am still getting some pull to the right however, even after setting alignment as accurately as I can. Is there some sort of rig for centering and holding the steering while checking alignment?
  Thanks all for the continued help and advice...
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
Re: CB 400F Carb adjustment and swingarm
« Reply #1 on: September 03, 2012, 07:42:04 PM »
i think a plugged air filter may cause slight richness, is yours new?  description of your plugs sounds like your bike is running pretty well.  pull strong everywhere?
in addition to the petcock fuel filter, i run an in-line filter too.  this may help eliminate plugging jets and various circuits w/particles that scoot past the oem filter.  don't forget to replace the fuel line(s).  bits of rubber can flake off the interior wall, causing multiple swearings and rants.
re: swingarm, i haven't heard of one getting bent other than a crash.  these bikes don't have enough power, nor is it delivered with enough gusto, to tweak this component.  (unless interior rust is present, maybe?)
anyhow, i'd get another  - probably cheap enough.  you may have fork tubes twisted in the triples, tho.  when traveling straight, are your bars at 90 degrees?
« Last Edit: September 03, 2012, 07:47:26 PM by steam-powered man »
searching for a dr350se
