Author Topic: Anyone tried the $120 CB550 big bore kit yet?  (Read 44498 times)
Offline P.abrera
Re: Anyone tried the $120 CB550 big bore kit yet?
« Reply #125 on: July 31, 2014, 07:58:49 PM »
Can anyone chime in with regards to the head gasket size/brand they used for the big bore kit?
Offline Tews19
  • I am no
« Reply #126 on: July 31, 2014, 08:06:17 PM »
It comes with a head gasket when you order the piston kit. You may have to email the seller of the kits on ebay.
1970 Honda CB750 survivor.
« Reply #127 on: July 31, 2014, 08:08:53 PM »
Make sure the head is nice and flat and use a MLS head gasket, best gaskets around... ;)
Offline P.abrera
« Reply #128 on: July 31, 2014, 09:47:41 PM »
im using an MLS, just chose the wrong size. Apparently theres a 62mm thats more suitable. Thanks
Offline P.abrera
« Reply #129 on: July 31, 2014, 09:48:47 PM »
mone were just the postons and rings. Will now ho with a 62 mm MLS gasket.
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #130 on: July 31, 2014, 10:31:11 PM »
getting close. any year now, lol.
I like berries.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #131 on: February 26, 2015, 12:01:35 PM »
Bumpity.
Has anyone had any pearls of wisdom to report about these 550 kits lately? I may doing it myself if I can find some current positive feedback.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #132 on: April 02, 2015, 11:15:18 AM »
Bumpity.
Same as the 836 kits that Hondaman has installed in a few bikes...the consensus is that they're good!
« Reply #133 on: April 02, 2015, 12:35:46 PM »
Has anyone had any clearance issues (with valves) with the Cruzin image 601cc kit?
« Last Edit: April 02, 2015, 12:42:14 PM by CB750 Cafe Racer Fan »
Offline FastCB550
    • Classic Honda Bulletin Board
« Reply #134 on: April 02, 2015, 01:08:04 PM »
I've had ZERO issues with my setup using stock valves and stock cam shaft. The pistons are the same height as stock pistons just a larger diameter.
1978 - CB550
600cc Overbore, Velocity Stacks, 4 into 1 Carpy Exhaust, Seat & Electronics by Kott Motorcycles, PD46C Carbs with 42 idle jets and 115 mains.
www.HondaBB.com
Offline Powderman
« Reply #135 on: April 02, 2015, 02:41:57 PM »
I've never heard anything bad about any of the Cruizinimage Big Bore kits. I have one on my CB400f (466)
They have had 6500 transactions in the last 12 months with 19 negative feedbacks, none of them for big bore kits. I think they are safe.
I had to laugh at one neutral feedback where the buyer bought a Suzuki piston with rings and pin. He was pissed because the picture looked like a "steel" piston and it turned out to be "cast crap metal". I wonder if he'd have been happier with a steel piston. :o
Out of 20 neutral feedbacks one was for a CB900 BB kit but the reply was in French "Qualite' Chinoise" (Quality Sieve)?
« Last Edit: April 02, 2015, 02:55:36 PM by Powderman »
Offline Scott S
« Reply #136 on: October 23, 2016, 12:34:35 PM »
 Has anyone ever calculated the compression ratio on this kit yet?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #137 on: October 23, 2016, 10:33:04 PM »
HondaMan mentions a lttle clean up work needed to relieve sharp edges on the pistons from CruisinImage.  Otherwise quality is good.  Idon't know anyone whom has mentioned it.  It is not the high compression kit from Dynoman...those are better quality but far more expensive...Often you get what you pay for. The CruisinImage kits are of great value and good quality.
I doubt they bump the compression up, they could  actually send it down, but not significantly.
You will develop more power from the bike having a bump in compression alone...just have to deal with a high compression motor's tuning and carb jetting areas to address.
Offline Canadian
« Reply #138 on: May 24, 2018, 12:42:52 AM »
Hi all,
Sorry to bring this topic back up. My cilinders are being bored as we speak, for this kit.
What is the clearance I should use between piston & cilinder ? In MM if possible ( I'm from Europe)
Thanks guys,
Brgds,
Elias
Offline Killer Canary
  • Typical Bran Muffin
« Reply #139 on: May 24, 2018, 06:31:12 AM »
Just starting the second summer on my rebuild.
I didn't use the rings or liners that came with the kit.
At the same time I installed a 650 cam and primary tensioner.Stock rejetted carbs and race baffle.
There has been no downside so far and an instantly noticeable increase in acceleration and roll on power.
And she sounds glorious. 8)
Kawi GPz900, H1
« Reply #140 on: May 24, 2018, 12:16:37 PM »
Previous pages list this...
In inch measurements the piston/cylinder clearance quote was  .0012-.0015"
In MM the quote is... piston / cylinder clearance   0,030 - 0,038 mm
Hi all,
Sorry to bring this topic back up. My cylinders are being bored as we speak, for this kit.
Thanks guys,
Brgds,
Elias
