SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
Other Bikes
Topic:
HELP!! honda cl360 wont idle down
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: HELP!! honda cl360 wont idle down (Read 1411 times)
sohcphreek
Full Member
on:
September 04, 2012, 01:11:38 pm »
My buddy bought this sweet cl360 it sat for awhile and now when he rides it the idle wants to continue revving very high!
He wants me to fix it so I thought somebody on here could sorta point me in the right direction. I have never messed with
vaccume/ diaphram carbs so not to sure what to expect.
Thanks sohcphreek
Logged
flybox1
My wife thinks I'm a
Really Old Timer ...
Re: HELP!! honda cl360 wont idle down
Reply #1 on:
September 04, 2012, 01:23:26 pm »
easy stuff first..
1. turn down the idle adjust screw.
2. check all the rubber boots between the airbox and carbs for air leaks.
Logged
'78 750K (F3 engine) PD42b's, Modified airbox w/K&N filter, 40/110 jets, 1 needle shim, IMS@ 1 turn out. Kerker + Cone 18" QuietCore
"This is my CB. There are many like it, but this one is mineā¦"
Johnie
Reply #2 on:
September 04, 2012, 02:17:21 pm »
Those bikes had trouble with the diaphram rubber under the carb cover getting cracks in the rubber. Might want to give that a look see. Easy to do by removing just 2 screws each.
Logged
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI USA
sohcphreek
Full Member
Reply #3 on:
September 11, 2012, 06:34:58 pm »
Thanks for the tips gonna work on it this weekend.
spray starting fluid around the boots?
sohcphreek
Logged
grcamna2
Not a
I love to restore & travel. Keep'em Going Strong !
Reply #4 on:
September 15, 2012, 09:58:48 am »
It'd be good to pull your points plate off and then pull out your timing advance unit and service it;the grease dries out,also check the 2 springs and make sure you have even & correct tension on both of them.
Logged
sohcphreek
Full Member
Reply #5 on:
October 03, 2012, 09:07:57 am »
got her idling perfect now but the clutch wont adjust slips under acceleration
Logged
kirkn
Expert
Reply #6 on:
October 03, 2012, 09:21:45 am »
What did you do, then, to get it idling correctly?
As for the clutch, if you have proper free play at the lever, then it sounds like you just have a garden-variety slipping clutch. That is, it needs new clutch plates.
Kirk
Logged
sohcphreek
Full Member
Reply #7 on:
October 03, 2012, 11:44:58 am »
I cleaned carbs and reset air/idle and set the idle and gave it a good shot of wd40!
I know real difficult stuff!
was hoping after some running and driving the plates might free-up? Can they be cleaned
or where should I get new plates, any tricks I need to know! or special tools required?
Thanks Chris
Logged
joesmotos
Enthusiast
Reply #8 on:
October 03, 2012, 05:32:31 pm »
You need to check the adjustment,loosen the cable adjusters and pop that little cover off where the clutch cable goes into the sprocket cover,loosen the locknut and back out the screw a little then screw it back in till it just touches,then back it off 1/4 turn and lock down the nut.Re-adjust cable and try it.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Other Bikes
Topic:
