Author Topic: Clutch Operated Switch  (Read 4647 times)
Offline pmpski_1
  • Beast V and Beast I
    • My CB550 related blog on MSN Spaces
« on: May 12, 2005, 01:19:26 PM »
According to the wiring diagram, I have a Clutch Operated Switch on my 74 CB550. It is supposed to fit into the clutch lever housing on the handlebars, but it's not attached. It's just hanging out, not connected to anything at all.
What is this switch for? What functionality is missing if it's not attached? The bike starts and runs and I can go through the gears without it.
Thanks,
Brian
Beast   I: 1974 CB550K
Beast IV: 1976 Chevy Blazer
Beast  V: 2003 Buell XB9S
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Clutch Operated Switch
« Reply #1 on: May 12, 2005, 01:26:53 PM »
In the litigation-mad US, the clutch switch did not allow the engine to be started unless the clutch was pulled in - just in case it was in gear and hurt the poor little rider...
Goes with the "Wear a helmet" and "Do not touch hot engine" stickers.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline pmpski_1
« Reply #2 on: May 12, 2005, 01:42:04 PM »
Hmmm... That's what I was thinking, but mine still starts with the clutch out (electric start). I think the two wires on the loose end are touching, allowing it to start anyway. I'll have to check it out. Thanks!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: May 12, 2005, 01:45:29 PM »
What do you mean "litigation-mad US!?" I'm going to sue you for that!  ;D
Offline cb650
« Reply #4 on: May 12, 2005, 02:42:08 PM »
[/quote
If its in neutral it will start with clutch out.  Try it in gear.
Remember this is the land where some stupid #$%* can spill coffee on herself in the drive through and win a lawsuit.
                        Terry
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #5 on: May 12, 2005, 05:04:58 PM »
The issue is your bike will not (or should not) start while IN GEAR unless the clutch is disengaged.  This is to prevent you from pushing the start button while in 1st gear, launching your bike into a crowd of pre-schoolers, nuns, baby seals, whales, the ozone layer or who/whatever we're saving today  ::)
It is a ROYAL PITA (pain in the backside) when your bike isn't running exactly perfectly, and tends to stall when warm at idle.  Without a functioning (key word - these switches do fail) switch, you can't push the start button while rolling in gear with the clutch pulled in.  You have to put the bike into neutral before starting.
Anyhow - check your wiring diagram, and hook the switch up.  Test it first though to make sure it functions.  If it doesn't, replace it - they're cheap ($10 or so new from Honda - I just picked mine up 2 hours ago  ;D)
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline pmpski_1
« Reply #6 on: May 12, 2005, 06:20:21 PM »
Aha, never tried starting it while it was in gear. It all makes sense now.
It looks like it's cut at the point where it connects to the clutch housing. I may be able to take it apart, strip a couple centimeters of wire and hook it up.
Thanks for the information!
