Author Topic: Mechanical rear disc for CB 750..  (Read 1060 times)
« on: September 07, 2012, 09:52:04 PM »
 Been toying with this idea..
 Got a CB 200 fork, has a cable operated disc.  10.25inch Disc weighs approx 4 lbs undrilled, 750 front weighs approx 6lbs. Bolt circle is a bit smaller, could use adaptor or carve out a new hub.
 Be easy to setup a cable brake, but anyone know if there is any stopping power? anyone tried this?
Re: Mechanical rear disc for CB 750..
« Reply #1 on: September 07, 2012, 10:09:33 PM »
I've ridden a couple of those little Honda's with the cable operated discs Frank, and they were pretty awful. Having said that though, they'd probably be fine for a rear brake, as normally your rear brake only represents 30 percent of your braking power.
I'm still looking for an original Hurst/Airheart rear disc conversion for a CB750, they were neat! I know CycleX does a copy but it's a bit half assed compared to the original. Cheers, Terry. ;D
Offline RFogelsong
« Reply #2 on: September 07, 2012, 10:23:50 PM »
If you need more force couldn't you use a pulley reducer of some sort and make your pad tolerance (overall pad travel) close enough to be able to use a standard lever?
Just an idea, I like where this may lead, lightweight and simplistic.
-Rob
Hondas past/present:
SOHC1:'74 CB125, '78 XL125
DOHC2:'71 CB450K
SOHC4:'73 350F, '75 400F, '75 550K
DOHC4:'81 900F, '01 1100XX
V4:'85 VF1000R, '86 VF500F, '08 VFR800
Offline trueblue
« Reply #3 on: September 08, 2012, 03:31:47 AM »
I have a little 200 twin in the shed and quite frankly the front brake is awful, but as Terry said it would possibly suffice for a rear.
1979 CB650Z
