Author Topic: New Plug Wires  (Read 7075 times)
happyonthunder
New Plug Wires
« on: May 12, 2005, 03:10:35 PM »
I have a 1977 CB550 with some nasty plug wires.
Can they be changed or do I have to replace the whole coil assembly?
Offline cben750f0
Re: New Plug Wires
« Reply #1 on: May 12, 2005, 05:54:23 PM »
mate do these have the wires bonded to the coils, if they do, go to you local NGK dealer, and buy cable splicers.. the part number is J-1... then go to you locl auto electrician, and buy a couple of metres of 7mm high tension lead, cut you old wires about 100mm/4" from the coils, then attatch your splicer and new lead cut to lengthl... easy... peace
Ibsen
Re: New Plug Wires
« Reply #2 on: May 12, 2005, 05:59:28 PM »
If you have coils with the plug wires moulded into the coils you can cut the old wires a couple if inches from the coils and splice on new wires. I will recommend that you use wires with a metal cord. You can either solder the cords and use a heat shrink tube to make a waterproof seal. You can also buy plug wire splicers made by NGK:
I used the first alternative on the plug wires on my Kawasaki twin, and it has worked fine for 8 years/35000 miles. :)
cb750_chris
Re: New Plug Wires
« Reply #3 on: May 12, 2005, 08:31:34 PM »
I have never heard of these splicers before.  Sounds like a great thing.
Don't newer Honda coils have sockets that you can remove the wires from?
You can get 6ft of the solid core wire from Den kirk for a few bucks.  It is much better to use than resistor wires.
If you have an electronic ignition you will need some NGK resistor boots though.  If not just use good ol non resistor boots.
Offline cben750f0
Re: New Plug Wires
« Reply #4 on: May 12, 2005, 10:00:47 PM »
no you dont need resistor wires.. they are there to stop ppl complaining when there radios get a buzz in them from the interferance from the ignition system... i run a DYNA's' on the F1 and use the metal core wires... peace
MotoDave
Re: New Plug Wires
« Reply #5 on: May 13, 2005, 10:13:36 AM »
You can also swap coils from a CB900 which have removable wires.
kaysystems
Re: New Plug Wires
« Reply #6 on: May 13, 2005, 04:21:16 PM »
They seem to wide (at the wire attachment) to fit under my K0 tank.
David
Offline cben750f0
Re: New Plug Wires
« Reply #7 on: May 13, 2005, 04:36:06 PM »
or make a mount and fit VF1000 coils...peace
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: New Plug Wires
« Reply #8 on: May 13, 2005, 04:41:11 PM »
I like the looks of that - would the VF1000 coils work well on any SOHC?  CB550F?
kaysystems
Re: New Plug Wires
« Reply #9 on: May 13, 2005, 04:42:03 PM »
I like it!!!
 ;D ;D ;D ;D
David
Offline cben750f0
Re: New Plug Wires
« Reply #10 on: May 13, 2005, 04:46:50 PM »
they are about 3.2 ohms.. so will have to check your charging system, but if its ok, you get a better spark, i am not sure how that will go with points and condensers, i am running a dyna'S', i originally had a set of '80 model cb750 custom coils, but as you ssaid they hit the insid of the tank, when trying to fit it, i then measured the distance between the coil mount holes when they were did by side and cut the '80 coil mount so that the vf coils bolted side by side with them minimun clearance between them,the  wireing colours are the same, so is just a mater of making a mount and plug and play...peace
kaysystems
Re: New Plug Wires
« Reply #11 on: May 13, 2005, 04:53:42 PM »
Thanks.
I'm running a Boyer Bransden ignition...the price was right...works a treat...
I'll look for coils at my favourite store...eBay
David
Offline cben750f0
Re: New Plug Wires
« Reply #12 on: May 13, 2005, 04:56:49 PM »
if you need and more pics, or one inparticular let me know and ill pull the tank and snap away... good ol dig cameras...peace
kaysystems
Re: New Plug Wires
« Reply #13 on: May 13, 2005, 05:15:10 PM »
OK I'll keep you in mind. I think I get the picture.
David
happyonthunder
Re: New Plug Wires
« Reply #14 on: May 13, 2005, 06:27:40 PM »
I'll try the wire splicers till I can score a new coil
Offline dpen
Re: New Plug Wires
« Reply #15 on: May 14, 2005, 11:19:35 AM »
If you go the route of soldering on new leads, cover the area with silastic before the heat shrink-beautifully waterproof leads
Offline dusterdude
Re: New Plug Wires
« Reply #16 on: May 16, 2005, 08:02:47 AM »
does anyone know where i can get the ngk plug wire splice kit.my local dealers either dont know or dont care to find out if they can get them.thanks
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline CB500_k2
  • Wrenching makes a good retirement.
Re: New Plug Wires
« Reply #17 on: May 16, 2005, 08:17:42 AM »
Try a bike shop.  They can order the splices for you if they do not have them in stock.  I ordered four from a local Suzuki dealer.  They are not fast moving items and the parts guy wanted to see how they worked when I got them since he had never seen on before.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline dusterdude
Re: New Plug Wires
« Reply #18 on: May 16, 2005, 09:25:46 AM »
groovy,how did they work out
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline dusterdude
Re: New Plug Wires
« Reply #19 on: May 16, 2005, 10:34:52 AM »
finally found a dealer that is getting them from parts unlimited.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline dusterdude
Re: New Plug Wires
« Reply #20 on: May 16, 2005, 11:21:52 AM »
ok guys help me out.what does the ohm rating on a coil actually have to deal with.i mean if i replace the 5 ohm coils with 3 ohm coils,what will i run into as far as any electrical problems go.thanks
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Ibsen
Re: New Plug Wires
« Reply #21 on: May 16, 2005, 11:45:18 AM »
You will have more current running through the points and they will wear out(burn up) faster. What you can do is to put a 2 ohm ballast resistor inline with the power lead to the coil.
« Last Edit: May 16, 2005, 11:52:18 AM by Ibsen »
Offline dusterdude
Re: New Plug Wires
« Reply #22 on: May 16, 2005, 11:50:25 AM »
thanks for the info
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: New Plug Wires
« Reply #23 on: May 16, 2005, 06:38:31 PM »
In case anyone is looking for splicers - 3 available:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4542397488
Offline Trevor from Warragul
Re: New Plug Wires
« Reply #24 on: May 17, 2005, 07:27:39 PM »
I used a "bodge" I picked up in Classic & Motorcycle Mechanics.  What you do is cut the head off a small nail & then sharpen it (so it's pointed at both ends).  Cut your wire about 3 inches short of the coil, then use pliers to stick the nail halfway into the wire.  Then push on the new wire & put some heatshrink over the top.  Crude, but works really well.
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
