Author Topic: Davies frame arrived today race on Saturday ????  (Read 12837 times)
Offline Howell
  • Honda the power of dreams
    • CB500 classic racing
Re: Davies frame arrived today race on Saturday ????
« Reply #25 on: September 13, 2012, 01:08:01 PM »
Hi Colin,
I hope this Davies frame has a longer live then ours.
We  had no 10.
I've heard that Davies has gone bankrupt , is that true ?
« Last Edit: September 13, 2012, 01:12:34 PM by Howell »
You meet the nicest people on a Honda
Offline Howell
« Reply #26 on: September 13, 2012, 01:19:47 PM »
Yolks arrived this mornings with shocks to follow tomorrow . Big thanks to John Davies at John Davies Motor sport for his help and support . Lovely bit of kit ( not John ---- the yolks !!)
To much offset for this yokes , cause very slow handling
See the picture for our yokes. ( in MM)
« Last Edit: September 13, 2012, 01:24:00 PM by Howell »
Offline simon#42
  • liverpool
« Reply #27 on: September 13, 2012, 01:35:59 PM »
that doesn't look enough offset  , you have effectively increased the trail making the steering even slower  this sort of offset would only work with a very steep steering head angle .
« Last Edit: September 13, 2012, 03:27:08 PM by simon#42 »
Offline Colin Tweedie
« Reply #28 on: September 13, 2012, 04:09:26 PM »
Howell.     I had the same yolks on my Tab K4 I can assure you the steering was quick , as for John going bankrupt I know he is watching this post so I am sure he will put you right
« Reply #29 on: September 13, 2012, 04:13:45 PM »
Another big night yolks , forks , mudgaurd  clipons all put together . .A few wee problems but I got there?..?
« Reply #30 on: September 13, 2012, 04:19:46 PM »
Had to make a spacer for disk so caliper would not foul on spokes ,bolts not long enough for disc to late to source longer , came up with a plan tho    ---- time serts   ??
« Reply #31 on: September 13, 2012, 04:38:28 PM »
Nearly sorted a wee bit jiggery pokery  tomorrow and I wiil be racing on Saturday
« Reply #32 on: September 13, 2012, 05:16:59 PM »
Exhausts fitted
« Reply #33 on: September 13, 2012, 05:48:25 PM »
Well done Colin. Good luck with all the jiggery pokery tomorrow. ;D
« Reply #34 on: September 13, 2012, 08:48:06 PM »
Go Colin Go!
Very nice job. How many hours at wartime production speed did you invest?
Offline HondaFreak
« Reply #35 on: September 14, 2012, 01:05:03 AM »
Well done Colin! never thought you would have had time really well done!! John certainly has not gone bust he is very busy and different frame orders coming in all the time. But he is absolutely hopeless on computers so very rare you here from him this way. Rene contact him direct and i am sure he will answer you. Good luck for
the w/end Colin you deserve it.  Peter
« Reply #36 on: September 14, 2012, 03:18:32 AM »
Not the place to discuss Johns business  he has been brilliant and took care of me . Back to the bike ?. At 11 o clock today (Friday 14 ) just need shocks and we are ready to  go the bikes not perfect or a pretty show piece all going well with the postman I should be racing tomorrow ,  exhaust not in line , fairing a b it squ wiff  give it character ??
Offline Howell
« Reply #37 on: September 14, 2012, 07:10:32 AM »
A friend of us has also a Davies framed 500 with the Davies yokes and he is not satisfied with it and want to change to the yokes we use.
On our bike these small ofset yokes worked very good.
A standard Honda has a stearing head angle of 26 deg. and a Davies 24,5 deg.
Offline Howell
« Reply #38 on: September 14, 2012, 07:13:17 AM »
Real nice bike and a very fast buildup Colin, I hope things will work good in the first race.
Offline NickO
« Reply #39 on: September 14, 2012, 07:24:22 AM »
Sorry for being a pedant Colin, but all this talk of YOLKS is making me hungry!  ;D
Yolks are found in eggs, bikes usually have YOKES. Perhaps our American cousins are right by avoiding confusion with their TRIPLE TREES?  ;)
  • Moderator
« Reply #40 on: September 14, 2012, 09:28:00 AM »
Yes Nicky boy, but are the tripple trees made of aluminium or aluminum ;D ;D ;D ;D ;D
Offline simon#42
  • liverpool
« Reply #41 on: September 14, 2012, 10:57:44 AM »
[/quote]
hi howell
you say that to much offset causes very slow handling  , my point was that this is the exact opposite of what happens . the less the offset the more the trail the slower the steering [ this is not subjective it is physics ].
the one and a half degrees change in head angle would only require a change of a few mm in offset [ if you really want i can work it out for you , will just need a few measurements ] not the huge change you have made .
i run slightly more offset on my aprilias which have a head angle of 21 degrees and a 17 inch wheels .
a bike with a head angle of 24.5 degrees using your yokes and an 18 inch wheel would be very slow steering at speed , i would hate to have to change direction on it mid corner .
Offline freedomgli
« Reply #42 on: September 14, 2012, 01:34:09 PM »
Wicked bike.  Good luck this weekend!
Offline fang
    • Food Renegade
« Reply #43 on: September 15, 2012, 10:02:18 AM »
Aaaamazingly fast build/rebuild.  I hope today's races are beyond fantastic.  Safety and happiness to you!
Download Nervous Norvus' "The Fang"  HERE.
Tired of eating CRAP!
« Reply #44 on: September 15, 2012, 03:36:17 PM »
That is absolutely correct.... ;)
« Reply #45 on: September 17, 2012, 01:30:54 PM »
Done it ----- two 10 min practice sessions and three 10 lap races ,not all good tho developed an oil leak second practice and almost went down with oil on my back wheel could not locate leak at the track but managed to stem flow with an old oil spill kit ( we were going to try a nappy but nae bairns in the paddock ) .Turned out to be the base gasket ?!  some other wee niggles other wise all ok
  • Moderator
« Reply #46 on: September 17, 2012, 02:38:51 PM »
Well at least you get to race another day Col, no harm done to the motor and more importantly none to you.
It was hell of a job just getting it race ready in the time that you had, well done mate.
Sam. ;)
Offline Jim F
  • go baby go
« Reply #47 on: September 17, 2012, 04:37:19 PM »
got to love those time serts
much better than heli coils
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline NickO
« Reply #48 on: September 18, 2012, 02:59:27 PM »
Well done Colin. We don't know one another, but I have to say for you to get out on the new framed bike in such a short space of time is nothing short of amazing.
Offline fastbroshi
  • Puppet
« Reply #49 on: September 18, 2012, 04:41:33 PM »
Collin, what fairings are you using?  They look the part.
Just call me Timmaaaaay!!!
