I have been stranded several times on my 77' 400F due to complete electrical shutdown. Dangerous especially when it happens in a low speed corner. I have traced the problem back to the red wire in the ignition assembly. I have had the entire assembly apart and it is obvious that the terminal connection where the ignition is plugged into the harness has a faulty prong on the red wire. Specifically, on the bottom of the ignition assembly, where the prong is rivited through the plastic to the small round terminal that gets bridged when the key is turned on. Its rivet is now loose and sloppy and making intermitant contact. I have tried folding the rivet edge over to stiffen the connection in combination with a coating of JB weld. It is now better, but still intermitant. I checked my spare parts bin and found an ignition that is very similar on the outside, but once opened reveals a different interior, so I can't scoop the parts. Is this just a difference in the year? Or, did honda have a couple of ignitions that they used depending on other variables? I realize this is pretty obscure....
