Author Topic: Tank rust - need a good inline filter as a temporary solution  (Read 1060 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: September 13, 2012, 12:29:01 PM »
Pulled my carbs off last night and found, among other things, that bowl #1 had a bunch of rust in it. I have a new petcock w/ filter AND an inline filter, so I thought I'd be okay. Wrong.
Looks like I'm going to have to deal with the rust in my tank. As y'all know, these F tanks are pricey - WHEN you can find 'em, even if they're in so/so shape. PO did a sh1t job of lining mine with Kreme, so I'll either have to remove the old liner & reline or look for a new tank (that may or may not need cleaning/painting/lining)...
In the meantime, it would seem that the crappy little plastic inline filter that I'm using isn't really filtering anything. So I'm looking for a better one. Suggestions?
Offline onepieceatatime
Re: Tank rust - need a good inline filter as a temporary solution
« Reply #1 on: September 13, 2012, 12:58:15 PM »
Show us what you are using?
Some of may be using the same thing, and like you, think it is working.
I got this one like cb650 posted from autozone:
http://www.hondacb650.com/viewtopic.php?f=3&t=6610&p=44032&hilit=fuel+filter#p44032
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Jiminy Indy
« Reply #2 on: September 13, 2012, 01:01:41 PM »
I like these because it's clear glass so you can see what's going on and the filter element is replaceable.
http://www.jpcycles.com/product/7200190
Of all the things I've lost, I miss my mind the most.
"Shot up the alley and then cut across the street" - now that's some violence you can appreciate!
Offline 2wheels
« Reply #3 on: September 13, 2012, 01:54:04 PM »
I had a paper element one for a while but it was too restrictive.  It was Ok for the top half of the tank but the bottom half it would not run right.
I like the looks of the one above.
But I use one of these, the 90 degree makes it easy to install on the 750F
« Last Edit: September 13, 2012, 01:56:03 PM by 2wheels »
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
