Author Topic: Piston ring filing  (Read 795 times)
Offline Davidov
  • 1978 CB750 F3
    • My CB750F project log
Piston ring filing
« on: September 14, 2012, 07:15:21 PM »
Should new piston rings (Standard bore) always need to be filed?
Bores are in spec, and the rings are STD sized. I haven't measured yet, but it seemed unnecessary.
I did quite a bit of searching, but I really want a clear answer on this.
-David
Offline wrenchmuch
Piston ring filing
« Reply #1 on: September 14, 2012, 07:32:04 PM »
Place the ring in the bore and push about 2/3rds down the bore using a piston to keep it square in the bore then measure end gap using a feeler gauge. When replacing rings in a standard bore
after a hone it's unlikely they'll need filing but you should check. Tight rings will cause a lot of damage.
CB750K1
CB750K4
bollingball
Re: Piston ring filing
« Reply #2 on: September 14, 2012, 08:37:11 PM »
 +1 wrenchmuch Not always that is why you Measure the ring end gap.
Ken
