Author Topic: chasing electrical issue CB750 - '73  (Read 6950 times)
Offline dylboss
« on: September 15, 2012, 01:01:24 PM »
So I recently aquired a '73 750 and been diving into getting it running.  Everything looks good, except I cannot get spark to any of the plugs.  All other electricals work.  Using a simple voltage light, I'm getting power to both coils from the kill switch, and I also tested both points when they were in the open state.  i have power to both.
I've been told that it would be extremely rare and unlikely that both coils would be junk at the same time.  I'm running out of ideas here.  Anybody?
Current
- 1972 CB750 K2 - Brier Brown Metallic
- 1973 CB750 K3 - Flake Sunrise Orange
- 1974 CB750 K4 - Flake Sunrise Orange
- 1976 CB750 K6 - Candy Antares Red
Previous
- 1978 Honda CB550K
- 1972 Honda CL350 Scrambler
- 1972 Honda CB450
- 1998 Suzuki TL1000R
- 1993 Yamaha FZR 600
Offline Steve_K
Re: chasing electrical issue CB750 - '73
« Reply #1 on: September 15, 2012, 03:58:45 PM »
Test the plug caps for resistance, should be between 5 & 7 K .  Cut a 1/4 to 3/8 inch off the coil wires.  Manually open and close points to make it spark.  Recheck wiring and not to be a smart a$$ check the killcheck  switch if it is on.  I know you said there was power to the coils, check  if it is the full 12 volts.  Recheck grounds and have a cold one while thinking about her.
Steve
Steve_K
Offline dylboss
« Reply #2 on: September 15, 2012, 08:26:01 PM »
Steve
Sorry, I'm not really an electrical guy.  What tool do I need to check for resistance?  I guess the most confusing part of this is that all 4 plugs are not getting spark.  Seems strange that all the plug caps would be bad.  I did cut one of them down and reattached the cap, with no success.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
Offline Spanner 1
« Reply #3 on: September 15, 2012, 08:30:04 PM »
Shine, I mean shine the point faces and try again..... ;)
Offline dylboss
« Reply #4 on: September 15, 2012, 08:39:30 PM »
Thanks, but given that I'm getting power at the points does that even matter at this point (no pun intended)?
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
Offline Spanner 1
« Reply #5 on: September 15, 2012, 09:16:39 PM »
Power at the points = great. But that only tells you that you have power at the points.
What also needs to happen is that the points close and ground the coil primary winding. If the point faces are covered in a film of corrosion ( will 'look' O.K. ), then the coil primaries cannot ground-out, saturate, and be ready to suddenly lose their energy when the points open which induces a high tension voltage in the coil secondary winding which then flashes across the plug ( spark )... So point faces need to be clean and shiny, point gaps need to be set and points need to open @ the 'F' mark..... :)
Offline jason41987
« Reply #6 on: September 15, 2012, 09:58:33 PM »
well, in order to get spark you need two things.. power, and timing... my bike had a similar issue, no spark, tested the resistance of the plug caps, and one was something like 4 million ohms, the rest didnt even register.. so my spark plug caps were all  junk, and the culprit..
touching your spark plug wires to a multimeter should get around 15,000 ohms i believe?.. if youre getting around that, coils are fine, check the caps, if you get around 5,000 ohms for newer caps or 10,000 ohms for older then they should be good, at this point id check the wiring leading to these coils for continuity, could have a broken wire somewhere... if not, its also possible somethings not grounded properly.. lastly, you could have a problem with the points or condensers which can also be checked and verified... theres a list of things to do, and i hope you have a multimeter
Offline dylboss
« Reply #7 on: September 15, 2012, 10:19:05 PM »
thanks for that explanation.  I did sand them down, and set the point gaps.  I'll revisit this.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
« Reply #8 on: September 15, 2012, 10:26:07 PM »
In case you don't know about points: here's how they points work:
They get [about] 12 volts thru the coils when they are open, and when they close, the current charges the coils. The Black/White wire feeds the "high" side of the coil(s), and the Blue (1-4) and Yellow (2-3) wires go to the points to get switched ON/OFF by the crankshaft. They essentially ground out the [blue or yellow] wire on the "low", or "switched" side of the coils, when closed. This charges the coil.
When the points open, the coil's magnetic field (which was built up by the current passing thru it) collapses, making the spark. If the points can't ground very well, this makes for poor (or no) spark, because the coil won't charge.
So, with the same meter you've been using: connect it with one side to the engine block, and the other to the Blue (1-4 coil) or Yellow (2-3) wire at the points, and see if it switches between 12-ish volts and ground (0 volts) when open or closed, respectively.
If it does, then the coil will make some sort of spark. If it does not switch to 0 volts, the points are not conducting, and need to be polished up good to make them work. That's the job of the points file.
Now...there are a few things that might not let the points ground. Two of those things are:
1. The bike's GREEN ground wire is not [properly] grounded to the frame. On the K3, it will be grounded in either: the seat latch bracket, under the seat, or: the front coil bracket, up under the gas tank. The K3 came both ways. If this Green wire is not grounded, it is real difficult to make spark.
2. The big, Black battery ground wire from the battery's (-) terminal must be connected directly to the engine. On the K3, this normally would be on the left top rear engine mount, in between the frame and engine bolster. If this is missing, again it is difficult to make a spark, since there is no ground for the sparkplugs.
Your friend is right: a double-coil failure at once would be one for the books!
You can check the coils, though, if you can figure out how to measure ohms (resistance) with your meter. If you figure that out, write back and someone will walk you thru it. The primary side of those coils should be about 4.6 ohms, the secondary (spark) side, with the plug caps removed, should be a few thousand ohms, tops.
« Last Edit: September 15, 2012, 10:27:39 PM by HondaMan »
Offline dylboss
« Reply #9 on: September 16, 2012, 06:16:35 PM »
Hondaman,
thanks so much for this info!  I will test all of this out tomorrow and post the results.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
Offline GR8WITE
« Reply #10 on: April 26, 2015, 02:22:23 PM »
anybody ever figure out what was causing this issue? Same exact problem on my bike.. power everywhere except to the plug wires. Came out of nowhere, the bike was running fine.
Offline Vinhead1957
« Reply #11 on: April 26, 2015, 06:35:30 PM »
There are two weak spots in the 73.  Trace 12V when the key is on.  The points should have 12v when they are open. 0 when they are closed.  The blk/wht wire from the headlight bucket gives power to the coils when the key is on and the kill switch is on.    The bucket is the first place. The second is the safety switch. It can be bypassed by jumping the green  and grn/red wire in the connector.
« Reply #12 on: April 26, 2015, 07:09:44 PM »
Kill switch on the handlebars?
