Author Topic: cb750G new project  (Read 6882 times)
Offline dimi3cb
cb750G new project
« on: September 16, 2012, 01:53:16 AM »
Hi All,
I just got a CB750 as I was in love in the look for years, and now it is my winter project to turn it to a cafe racer. As I do not have a lot of experience but the will to learn is there so I will need your expertise. thank you in advance!
CB750 is very rare in Serbia so forum is my source.
First question is: Which year and model is my CB750 as I did not find the proper documentation? To start ordering parts
frame number is: CB750G-1014068
Let the games begin
Re: cb750G new project
« Reply #1 on: September 16, 2012, 05:14:03 AM »
G'Day Dimi, that's a 1977 CB750F2 mate. Welcome to the forums! Cheers, Terry. ;D
« Reply #2 on: September 16, 2012, 07:55:40 AM »
Welcome Dimi.  Terry knows and loves these F bikes, so I would trust his word.
Isn't there a VIN plate on the frame that has the model year? Where did you find the bike?
« Reply #3 on: September 16, 2012, 08:27:21 AM »
CB750G, huh?! No G's in the US. Just F's and K's. Nice looking bike. It looks like a combination of the F and the K. F basically with a K looking tank and some of the rear end. Can't say for sure about the seat though. Looks aftermarket.
I cruised CMSNL.com and did not see a G listed.
« Reply #4 on: September 17, 2012, 12:50:29 AM »
Nah, it's not really a "G" Jerry, some the non-US frame/VIN numbers on F2's start with CB750G- Cheers, Terry. ;D
Offline Picasoo
« Reply #5 on: September 17, 2012, 01:50:06 AM »
Welcome my fellow Serb...! :)
You're on the right place for all technical details and advices, these guys are awesome!!
Dobrodosao prijatelju, mislim da smo se ja i ti culi telefonom!?
Pozdrav iz Svilajnca!!
'75 cb750F super sport
Offline dimi3cb
« Reply #6 on: September 17, 2012, 03:00:51 AM »
Hi all,
Thank you very much for the information. Looks like it is 1977 CB750 F2.
I found it in Serbia rotting away in a garage, they are beutiful bikes but the 70s model is very rare here. So after a lot of price negotiation i brought it home with a truck. A quick replacement of spark plughs, oils, filters, new battery, carb cleaning and new float needles it started up like a kitten.
It was fine for 2 days and then cylinder no1. stoped working and now it wont start at all.
I hear some noise also from some chain inside when i tilt the bike to the left, I am not sure what it is. Looks like it will need complete engine overhaul.
Seat is giuliari aftermarket for CB750. I like it a lot.
the first idea for the design looks like this. What do you think?
« Reply #7 on: September 17, 2012, 03:42:28 AM »
Yeah mate, it's an F2, but it's been extensively modified, with a K series tank, rear fender etc. This is a pic of my "close to original" F2:
Cheers, Terry. ;D
Offline dimi3cb
« Reply #8 on: September 17, 2012, 03:59:36 AM »
WOW yours looks beutiful....
I like the exchaust especially.
Here is a better picture of the bike from another angle
I will keep the modifications I like it like this. Too bad I do not have any documentation or the history, but puzzles are being put together.
can not wait for the next spring to see it refurbished, I hope.
Offline krusty
« Reply #9 on: September 17, 2012, 04:19:25 AM »
I've recently acquired an F2. Frame #CB750G 1015551, it's a May1978.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
« Reply #10 on: September 17, 2012, 04:47:38 AM »
Yeah mate, I like the look of your bike too, it's not as "slab sided" as a standard "F" bike with that K series tank, seat and fender treatment.
Years ago I'd thought about building a bike like yours out of some K and F "leftovers" but never got around to it, but at the time, I thought it'd be a perfect marriage of the best of both models. Tell me more about your engine problems?
Here's a pic of my current bike, I've got a seat just like yours! Cheers, Terry. ;D
Offline Picasoo
« Reply #11 on: September 18, 2012, 02:39:24 AM »
Samo napred...!!
Offline dimi3cb
« Reply #12 on: September 18, 2012, 03:39:30 AM »
Bike is looking excellent Terry. I was actually thinking how it would look with blue and yellow a bot of Swedish styling:) now I see.
I wish I could get mine to look like this for the next year.
The brake and the covers are great. You can see a lot of time and love went in to this machine.
I am trying to start up mine but cylinder 1 does not work. I think carb is leaking too much fuel and spark plug gets dirty...
What do you think about rattling noise when I tilt the bike to the left when the engine is working?
dimitrije
Offline Picasoo
« Reply #13 on: September 18, 2012, 04:13:08 AM »
About cyl No.1-Check float level...
About noise - check the main chain and oil level!
« Reply #14 on: September 20, 2012, 03:08:00 AM »
The F2 carbs are notorious for blocked idle jets mate, and most of the problems I've seen with them not firing in one cylinder has proven to be a blocked idle jet. The idle jets are pressed in, but you can remove them with vice-grip pliers or similar, and use a really fine wire (or guitar string) to clean it until you can see daylight when looking thru it.
The rattle can be a lot of things, a really loose cam chain, (caused by a siezed adjuster) electric starter/starter clutch issue, loose alternator rotor bolt etc. Sadly it's a case or "try one thing, and if that doesn't work, try something else". I had a constant rattle and swapped out the front sprocket, replaced the starter clutch screws, checked the rotor bolt for tightness etc, and it was only when I swapped out the starter motor (which was sluggish in operation) that the noise went away. Good luck! Cheers, Terry. ;D
Offline Magilla
  • My bike: 1976 CB750F
« Reply #15 on: September 21, 2012, 07:19:41 AM »
Terry,  I like that Frankenbike side cover on your bike.  This is the first time I have seen one painted and on the bike.  I really like it.  I should have bought a set at Rice O Rama when I saw them.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Killer Canary
  • Typical Bran Muffin
« Reply #16 on: September 21, 2012, 09:54:32 AM »
Dimi, what's that deal between the speedo  and tach? It looks like something from a Suzuki RE.
Kawi GPz900, H1
« Reply #17 on: September 21, 2012, 03:42:24 PM »
Thanks mate, that's not the best angle to really see the excellent work Joe did with them, those fins slightly curve around the circumference of the covers and look sweet from other angles. There are several suppliers if finned covers out there now, but Joes are up there with the best, at a much cheaper price! Cheers, Terry. ;D
