Author Topic: Northern ireland cb550 cafe build bike finished  (Read 30426 times)
Offline stuartni
« on: September 16, 2012, 09:55:02 AM »
 My father in law has raced bikes and sidecars all his life and has got himself hooked with the street tracker/cafe look, We are currently building about to finish a 1979 yamaha xs500 he had laying in his yard for over 10 years, the plan for it was do it as cheap as we can but still nice and use it as a spare bike. ( i will post pics of this also) i finally bought this 1978 cb550 four around 3 months ago looked a good clean bike for its age plans are to make into a cafe racer. pics to fallow later today
Here is northern Ireland there is such a small market for bike parts unlike america which has everything i could ever want  i want club man handle bars for my bike but as there is no where here sells them im not sure what ones to go far as there a few different pull backs etc finding parts here is very hard second hand or new.
bike is stock bar
dragstar handle bars
motad exhaust
so far the only problem we could fit with the bike is its not charging and it already had new regulator/rectifier but still it was not charging we then tested the system and found that the new r/r was not the correct one for the bike, bought a new one and the bikes was now charging but under load (headlight on) best we could get was 11.6 volts which not good so did more tests ad found the stator to be faulty so after a bit of searching on the internet it seemed i would have to get it rewond at around £100. Then by sure luck a friend of my father in laws said he has a cb 550 four in bits which is the only model with the same alternator and he gave me his for free. Best of all his was in great working order and fixed my chartering issue
when i picked up the bike
love the wheels anyone know what they are think they say cma on the side of them
« Last Edit: November 04, 2014, 01:20:47 AM by stuartni »
Offline stuartni
Re: Northern ireland cb550 cafe build
« Reply #1 on: September 16, 2012, 09:55:52 AM »
wiring diagram
loom all labelled
taped up all the bracket i want to remove
carbs removed
tabs etc removed
engine ready to come out
framw stripped
old oil look good must have been serviced not long ago
engine out
all the parts
« Last Edit: January 29, 2013, 02:25:44 AM by stuartni »
Offline Tews19
  • I am no
« Reply #2 on: September 21, 2012, 08:19:41 PM »
Nice progress... crazy looking rims. What are they?
1970 Honda CB750 survivor.
Offline IRISHCBRACER
    • My first build - 1976 CB550
« Reply #3 on: September 21, 2012, 10:50:58 PM »
Good luck with the project! I'm from Newry but live in California building a CB550 cafe.
Offline stuartni
« Reply #4 on: September 22, 2012, 02:02:52 AM »
tews17 -  we arent sure what the wheels are they say cma on the side of them. Tired to google them but cant anything on them.Father inlaws mate said he remembers them in the 70/80s and said they where very expensive back then
Offline stuartni
« Reply #5 on: September 22, 2012, 02:13:05 AM »
irishcbracer - long ago did you move to america, its terrible here for any classic bike parts and was looking at your build its looking really good so far. Where did you get the exhaust thats exactly what i want but there is no where can make it. i will upload alot more pictures of the build today :D
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: September 30, 2012, 04:15:45 PM »
Hi Stuart, I'm in Bangor. What are you doing with the bits you remove? If you need a hand with anything give me a shout, I have a 77 550.
Offline stuartni
« Reply #7 on: October 14, 2012, 09:03:30 AM »
more updates progress has been slow as we are building a better work shop for our selfs
anyone know what these are wheels are??
bits no longer needed
my home made shot blasting cabinet
xs 500 engine being done
after
before
after
before
after
more cb550 parts being done
« Last Edit: January 29, 2013, 02:26:41 AM by stuartni »
Offline stuartni
« Reply #8 on: October 14, 2012, 09:16:31 AM »
frame getting cleaned up
forks need to good overhall new fork oil fork seals and dust covers
new bits
forgot i good the hubs with this bike and forgot there was a good disc on it which saves me buying another for the twin disc set up
tank and frame shot blasting and into primer tank has knee dents also put in
32962F1FE4.jpg[/IMG]
only sign of rust damage
in primer
« Last Edit: January 29, 2013, 02:27:14 AM by stuartni »
« Reply #9 on: October 14, 2012, 04:07:33 PM »
Nice progress, subscribed...
  • 1977 CB550F2
« Reply #10 on: October 16, 2012, 04:51:35 AM »
I be interested in those headlamp brackets Stuart.
Offline stuartni
« Reply #11 on: October 17, 2012, 02:06:43 AM »
Hello yes mate no problem i get the bits later and see what i have pm me your contact number
Offline stuartni
« Reply #12 on: October 26, 2012, 05:43:14 AM »
finally more up dates
work shop 90% finished flooring fixed walls plastered, 4 coats of paint and the floor painted
 front wheel cleaned back to bar alloy and in etch primer
plans have completely changed for the rear end as i want to hide all the electrics and battery and my old plans would not allow for this so standard style hoop has been welded in
all these parts where stripped of rust paint etc and into primer
starter motor you dont even see it but still worth doing rite so same again all dirt/crap removed then primed and painted
before
after
engine has been cleaned up a bit with degreaser and a power hose but still loads more to do to it
my free rearsets given to me from the father in laws old race bike gsxr k7. new mounting brackets are being made for the rearsets so there a bit lower
i want this exhaust so much but so hard to get so if anyone knows of anywhere in northern ireland that could make the main tail piece section i would be happy as i can just use my current stainless down pipes
looks like this when fitted
rear trim pieces have been removed from the old rear section and trimmed down to fit to keep the clean lines
how things are currently looking engine is in just to check the fitment for the rear sets and started to make the pod out of oasis flower pot foam trim it to the shape i like tap it up and wax it then use it as my template to make my fibreglass seat.
still alot more trimming to be done
rear bracket and rear brakes housing now removed to make way new brackets for the rear sets
plan do something similar to this
rear wheel starting to get cleaned up
« Last Edit: January 29, 2013, 02:27:47 AM by stuartni »
Offline stuartni
« Reply #13 on: November 21, 2012, 04:51:04 AM »
more updates on there way  :D
« Reply #14 on: November 21, 2012, 05:17:47 AM »
looking good.  You sure are working fast :)
Offline iron_worker
« Reply #15 on: November 21, 2012, 06:04:08 AM »
Makes me wish I had a blast cabinet. Coming along nicely man.
IW
Offline stuartni
« Reply #16 on: November 21, 2012, 07:01:10 AM »
yea cant wait to get it on the road so every free chance i get im out working on it frame swing arm forks and most of the other parts are now in paint not long till the building process begins  ;D
Offline greenjeans
  • 1972 CB750K2
« Reply #17 on: November 21, 2012, 07:08:07 AM »
Wow - you most fast.    I don't even remeber seeing rims like those - they are great.    Are they aluminum or magnesium ??
They almost look dull/darker than aluminum.      Keep going - great looking bike.
  • 1977 CB550F2
« Reply #18 on: November 21, 2012, 09:00:43 AM »
Ever find that seat lock Stuart?
If you are going to have it ready soon you'd better put some skis on it. :)
« Last Edit: November 21, 2012, 09:02:48 AM by LesterPiglet »
Offline stuartni
« Reply #19 on: November 22, 2012, 12:51:14 AM »
seat pod template made
the fibreglass mod
design for the drilled discs
shortened a little
hagan rear shock with new top bushes
seat pod starting to get smoothed and custom taillight fitted
sorting the wiring and new gel battery
new spray gun ready to go
frame ready to be painted
wheels swing arm and focus painted
new all balls taper bearings
frame swing arm forks etc are also just back from getting lacquered
« Last Edit: January 29, 2013, 02:28:16 AM by stuartni »
Offline IAmCitizenMe
« Reply #20 on: November 22, 2012, 09:06:48 AM »
Followed. This is great.
Offline Bluegreen
« Reply #21 on: November 22, 2012, 11:10:57 PM »
Subscribed !!
Offline stuartni
« Reply #22 on: November 23, 2012, 06:29:50 AM »
thanks foe the comments  :)
more parts getting ready for primer
new battery strap
brackets will be dressed up once i happy with all the fitment
the frame swing arm forks etc where away get lacquered as i wanted it down in a spray booth due to our winter being so wet and cold
main enigne block cleaned and painted with rocker cover side covers going black
« Last Edit: January 29, 2013, 02:28:37 AM by stuartni »
Offline stuartni
« Reply #23 on: November 29, 2012, 06:43:08 AM »
using this for now but would like a new one
still to be cleaned and painted
honda kick stand spring from usa cause i wanted black could only get silver here
engine now in finally also the engine will be back out after next summer to get a complete rebuild with alot of uprated parts even tho is it running fine, so for now a good clean and some paint will be good enough
also tapped cover are getting polished not paint like in the pictures
also have new front and rear wheel bearings new cables one new tappet cover as one was damaged new front and rear sprockets
new speedo and tyres should turn up today
« Last Edit: January 29, 2013, 02:29:00 AM by stuartni »
Offline iron_worker
« Reply #24 on: November 29, 2012, 06:58:58 AM »
Wow! Great progress here. I think you started your build thread after me and you're already zooming past. ha
IW
