Author Topic: Northern ireland cb550 cafe build bike finished  (Read 29059 times)
Offline stuartni
Re: Northern ireland cb550 cafe build
« Reply #25 on: November 30, 2012, 12:34:18 AM »
lol ive been at it every night and most weekends i can decided i no longer want to use the alloy wheels so need to get rims and spokes can i run a wider rim so can run wider front and rear tyres
Offline iron_worker
« Reply #26 on: November 30, 2012, 08:57:46 AM »
I personally love the spoked wheels on these bikes. I think they look great all chromed up.
IW
Offline Bankerdanny
  • Endeavor to persevere
« Reply #27 on: November 30, 2012, 02:23:28 PM »
The stock swingarm doesn't allow for a very wide tire, you might find that the wheels you have will allow for the extra width you want, or at least what the fork and swingarm will support.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #28 on: December 06, 2012, 06:59:28 AM »
I have a 130/80 on the rear and it JUST fits. The first thing it will touch is the chainguard then the swinging arm.
Offline stuartni
« Reply #29 on: December 07, 2012, 04:38:47 AM »
should been some updates over the wknd here def going down the spoke wheels route dont want to use the alloys now
Offline stuartni
« Reply #30 on: January 18, 2013, 07:49:07 AM »
more updates very soon 8)
Offline stuartni
« Reply #31 on: January 29, 2013, 06:58:02 AM »
Heres a video of the bike before work started bike had just been started before i took the video on a very cold morning
http://youtu.be/J_-ClMHI14Q
« Last Edit: January 29, 2013, 07:27:20 AM by stuartni »
Offline edhaeuser
« Reply #32 on: January 29, 2013, 09:14:15 AM »
Great progress!!!  You will certainly have some awesome roads to run it on when you are done!  I would love to get back to Belfast some day.
Ed
Offline stuartni
« Reply #33 on: January 30, 2013, 03:33:00 AM »
thanks yes some great roads for us to travel here 8) When where you last in Northern Ireland i wish we had more sun here to enjoy more bike runs rain sucks  >:(
Offline edhaeuser
« Reply #34 on: January 30, 2013, 08:12:25 AM »
I believe it was August of last year.  I was there for work and in and out of Belfast for two weeks.  I was able to spend two weekends free from any work duty in Belfast.  Heard some great Blues music.
Have you tried contacting David Silver Spares UK directly about pipes?  Maybe they can get something.
« Last Edit: January 30, 2013, 08:26:52 AM by edhaeuser »
Offline stuartni
« Reply #35 on: January 31, 2013, 04:09:07 AM »
yes they only really do motad system or oem and very nice some of the coastal runs are really nice cant wait to take the bike round them in the summer
Offline stuartni
« Reply #36 on: February 06, 2013, 01:15:54 AM »
a few more updates work has been slow but rims and one disc are away to be powder coated and both discs are now drilled in my design
alot of wiring has been done loom shortened and repaired where needed looks messy but isnt really
controls prepped primed and painted
working out where to put my led lights for oil pressure turn signal neutral and full beam
Here worked out good for two of them
Offline stuartni
« Reply #37 on: February 07, 2013, 05:14:07 AM »
rims and disc back from the being shot blasted and powder coated  8)
Offline iron_worker
« Reply #38 on: February 07, 2013, 06:04:40 AM »
I wasn't sure if sand blasting the disc brake surface was a good idea or not so I had them tape mine. Any thoughts on that?
IW
Offline stuartni
« Reply #39 on: February 07, 2013, 07:46:55 AM »
i cant see it doing any harm as a brake pad will bring it back to way it was pretty quickly and the place that done it said they have done the hole disc a few times before with never an issue
Offline stuartni
« Reply #40 on: February 20, 2013, 02:17:36 AM »
more updates rims build tyres fitted etc
disc painted just need lacquer
rear wheel ready to go on
bike rolling again
now with twin disc setup have to modify the disc and standard speedo drive alot to let them fit together
« Last Edit: February 20, 2013, 03:33:53 AM by stuartni »
Offline IRISHCBRACER
    • My first build - 1976 CB550
« Reply #41 on: February 20, 2013, 08:37:16 PM »
Will she be ready for the NW200? I'm coming home from California to watch the race  8)
Offline stuartni
« Reply #42 on: February 21, 2013, 01:35:45 AM »
yes i plan to have it completed by then for sure as my friend wants a few of us to head down on our bikes  8) we could meet and let you see the bike is all its glory  ;D the only thing stopping me from finishing this bike now is money as the exhaust might have to be custom made and the so does the seat plus a few other bits and bobs
Offline stuartni
« Reply #43 on: February 24, 2013, 10:33:52 AM »
Newest addition to bike family found this thanks to norniron400f he seen it phoned me and on the fridsy night and I bought it the next morning its a cb550 with a cb650 engine has electronic ignition and box loads of parts
Offline stuartni
Re: Northern ireland cb550 cafe build on its wheel and another bike purchased
« Reply #44 on: February 27, 2013, 04:16:09 AM »
few more updates finished some more of the wring and connected up the battery
ignition relocated to here doesnt look in the best order but works fine matched the tank lock
carbs where taken all cleaned inside and out then painted ready to go on
Offline sinister902
    • Anger Street Kustoms
« Reply #45 on: February 27, 2013, 09:37:28 AM »
nice quick progress...
Offline stuartni
« Reply #46 on: February 28, 2013, 12:55:13 AM »
thank im trying my best to do at least hour or two every night after work
Offline stuartni
little bit of an update havent had much time at the bike but thanks to scott s of here we did a trade he needed shorter rear shocks i needed longer rear shocks to stop the rear end bottoming out, they came all the way from south carolina . Have also made and painted a speedo drive bracket to stop it from hitting the disc and half way through making a rear number plate bracket. Got the horn on as well but going to take it off again and paint the bracket.
made amazing private reg from the other cb550 i bought reg is XOI 5504
Offline stuartni
small update
rear brake setup finished just need paint the bracket etc
bracket made for the brake fluid bottle and throttle cables fitted
  • 1977 CB550F2
Your rear brake is assembled incorrectly....or is that done from neccessity?
The chrome arm on the brake hub should be pointing down.
