The SOHC/4 World Tour is in under way.
I converted my switchgear all over to push button and went with the Nissin m/c. My current set up only has 2 buttons on each bar. One button is the horn , another does the hi/low and off for the head lamp. The last 2 are for the directionals. My starter is a separate push button, but it's mounted up near the guages. Im using a Motogadget M-Unit to make all this work. The switch gear is Motogadget as well.
Quote from: matt mattison on September 17, 2012, 01:47:06 AMI converted my switchgear all over to push button and went with the Nissin m/c. My current set up only has 2 buttons on each bar. One button is the horn , another does the hi/low and off for the head lamp. The last 2 are for the directionals. My starter is a separate push button, but it's mounted up near the guages. Im using a Motogadget M-Unit to make all this work. The switch gear is Motogadget as well. I'd love to see this up close. Got pics?[/quote]
How simple you trying to go? Switches are on the tree.Foot clutch, foot brake.Internal throttle.
My K8 with K&S switch gear , Nissin M/C , Tarozzi clip on's , shaved top tree , Acewell , stock tach . I hate these bars !
Quote from: george on September 17, 2012, 08:13:59 PMMy K8 with K&S switch gear , Nissin M/C , Tarozzi clip on's , shaved top tree , Acewell , stock tach . I hate these bars !Clean setup. How'd you mount the tach?
Quote from: george on September 17, 2012, 08:13:59 PMMy K8 with K&S switch gear , Nissin M/C , Tarozzi clip on's , shaved top tree , Acewell , stock tach . I hate these bars !George do you have a link for K&S? I looked and came up with a ton of hits but not what you are talking aboutKen
