Author Topic: 550 twin brake, which bits work ok?  (Read 1485 times)
Offline simonuk
« on: September 20, 2012, 10:56:20 AM »
Can somebody help please?
I have a 550k3 and although it stops the brakes are pretty poor. I have a second front caliper and swing bracket but wondered what else I need to make the setup work?
I think I need another master cylinder but which one?, does the gl1000 one work ok? Also I need a splitter for the lines below the lower fork tree, the standard one is for one line in and one line out plus a brake switch only. I will need the brake switch so it must run three conections.
Thanks a lot
Simon
Re: 550 twin brake, which bits work ok?
« Reply #1 on: September 20, 2012, 11:10:27 AM »
On 750 I used dual banjo bolt to split brake lines. Also the original MC is big enough for the dual setup.
Some info:
http://forums.sohc4.net/index.php?topic=110116.0
