Author Topic: CB750k7 Project: Operation Street Fighter (On the Road, Carb tuning in progress)  (Read 24967 times)
Offline iron_worker
Re: CB750k7 Project: Operation Street Fighter (Piston Fit questions)
« Reply #75 on: March 26, 2013, 11:53:55 AM »
Calipers are not the proper tool to be measuring inside diameters. A dial bore gauge or an inside micrometer should be used to get an accurate measurement.
IW
Offline Vinhead1957
« Reply #76 on: March 26, 2013, 12:45:09 PM »
I think he is talking about the outside of the pistons
Offline Vinhead1957
« Reply #77 on: March 26, 2013, 12:56:24 PM »
I would think his video method Is not reliable due to the wear is only where rings ride the upper cylinder may have a lip so to speak. It needs to be checked as you have stated north south east and west
Offline laminaytrap
    • Satchealous Garage
« Reply #78 on: March 26, 2013, 12:57:27 PM »
Indeed, the pistons measure as above which is what I am interested in, skirts are the same all the way down, but the top is curved in
Offline snowman
Re: Triple clamp offset
« Reply #79 on: March 26, 2013, 02:36:43 PM »
So if anyone wants to jump in on this,
I am thinking about making custom triples as i have some access to CNC equipment.
I'm thinking of something like these, i like the clamp design and the adjustable offset.
Any further news on the triple trees?
Offline laminaytrap
« Reply #80 on: March 26, 2013, 02:39:09 PM »
Did not end up making triples. I adapted the ZX-6 front end using the CB750 spindle and a bit of machining work.
Offline laminaytrap
« Reply #81 on: April 01, 2013, 07:50:26 AM »
So it turns out that it is quite normal for the crown of the piston to taper in. My bores measured out .001-.002 out of round, so worth reboring, but not nearly as bad as I thought. Need to get my drinking under control ;)
In other news the swingarm is almost done, sold my front end and the rear wheel is pending pickup.
Still need to find:
X Front wheel
X Brake lines
X Tires
Petcock
Pistons _ ordered
Gaskets _ ordered
Rear master _ overrated
Need to fab:
X Tank relocation
X Wheel spacers
X Cushion mounts
X Headlight mount
Seat _ overrated
And get the motor bored and reassembled
3 weeks, lets go. She may not be pretty by then, but she's gotta work.
« Last Edit: April 19, 2013, 10:28:52 AM by laminaytrap »
Offline laminaytrap
« Reply #82 on: April 17, 2013, 07:57:38 PM »
So I haven't posted here in a while, been busy with school and whatnot. Also got some bike work done...
I got a rear wheel
Did some swingarm work
And a front wheel and tires. A CB 750 does fit in a toyota matrix, just in case you were wondering. My GF's car.
And the finished-ish frame as it sits. I didnt like the lower shock mount so it was replaced with a steel version to lower it a bit and give me some peace of mind.
Unfortunately my pistons seem to be not here yet, as well as the rest of my motor parts :(. So my Sunday deadline will probably come and go, but maybe next week will be better...
Offline laminaytrap
and i machined up the rear caliper slider block
Offline iron_worker
Bike is going to look pretty bad@ss with those meats on there.  8)
IW
Offline Strangexj86
looking great man! That swing arm is awesome! You going to powdercoat it? Wheels look good too. super beefy.
1989 BMW e30 s52 turbo (illegitimate love child)
1989 Mercedes 420SEL (baby)
1978 cb550four (In progress)
http://www.r3vlimited.com/board/showthread.php?t=192128http://www.r3vlimited.com/board/showthread.php?t=215540
Offline laminaytrap
Yeah, the 180 tire looks right at home back there, just wish I had a motor to put in.
And no, no time or money for that sht
Spray bombs lets go... Maybe next winter after the bugs are ironed out and the swingarm has broken once or twice...
Offline laminaytrap
Rear caliper bracket V2...
Now with shoulder bolts!
Offline Stilltime
  • Building my Dream
As an ME I love the CAD/analysis design!  Awesome work!  Your ideas look great.
'78 CB550 - Orange Crush
Offline laminaytrap
PIC DROP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Headlight Ears are another kawi lower triple clamp cut up with tabs on them.
Front End is ZX6, as are wheels
Rear Shock is F4i Showa, 795LB/IN
Offline sander
Nice project! I like where this is going. Do you plan to keep the clipons mounted this way? (i hope not....)
Offline laminaytrap
Not likely, but I needed them to clear the tank easily for now, after everything is installed properly I'll look at dialing bar positions
Offline laminaytrap
Motor is in place for transport... If anyone has any style suggestion you should make them now, cause next week the details will all be finished up.
Offline dragracer
  • CB750F Dragbike
I'm more into dragracing but i like the way you're doing the streetfighter look on this build. Great  work so far with the monoshock set up and ZX frontend. Looking forward to the final product.
Offline laminaytrap
Wow, so I apologize for letting this one die for so long, but i have news!
Despite major setbacks in the motor department, the bike is now on the road and 95% complete.
Parts Case
Motor Assembled
Final Mock up
Back to original ('76) Keihin Carbs
Road Ready...
Awful Cell pic of Exhaust mockup. Style is ok, implementation is questionable. May order some stainless UJ bends and trim a third off the can to clear the arm. Time will tell
Offline GNGSXR
which CAD program are you specifically using for your renderings, 3D models, and finite element modeling?
1971 CB750
1980 CB750
1996 Honda CBR 600F3
2006 GSXR 750
1987 Buick Grand National
Offline laminaytrap
Nowadays I use solidworks 2011, in the past I used UGS nx8.
I think everything in this thread is SW2011
Offline laminaytrap
I'm going to try to do a photo/vid shoot tomorrow or sunday. Still trying to get my hands on jets so i can get this show on the road. Had to tape off 70% of the pod area so she wouldn't overheat and explode, now fire shoots out of the exhaust when you go on or off the throttle, but boy she pulls at WOT. Can't wait to stop fighting her and start riding her  ;)
And a question if anyone is still watching this thread. The muffler is a Hindle Stealth ~24" Glass Pack 2" inside. Is that enough flow or should I make up some new internals for the can. It'd be simple enough to convert it to 2.25 or 2.5 to match the rest of the system. Or on the same card cut it in half and run a short pipe on each side split just post collector? Opinions welcome. I've always enjoyed single sided systems on everything, but then I've never had dual pipes...
The bike isn't symmetrical, so why should it look the same on both sides? A pair of 12" pipes may end up much louder than now too, which is borderline. It would probably look pretty cool too.
Anyways, its good to be back. Come by and say hi!
Jon
« Last Edit: September 25, 2013, 07:48:08 PM by laminaytrap »
Sorry if i've asked this before but what did you use to get the gold finish on the head and barrels..?
Offline laminaytrap
« Last Edit: September 26, 2013, 09:43:54 PM by laminaytrap »
