Author Topic: Top End Help! - Kickstart Stuck after rebuild  (Read 4400 times)
Offline luap
  • LAWL
Re: Top End Help! - Kickstart Stuck after rebuild
« Reply #25 on: September 22, 2012, 06:03:36 PM »
pull the head off an start over double checking everything
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline Mo
« Reply #26 on: September 22, 2012, 06:30:09 PM »
I was hoping to avoid that but I guess not..
What should I be looking for?
Offline mickwinf
« Reply #27 on: September 23, 2012, 01:49:51 AM »
i am wondering if you put the camchain guide at the front of the engine in the wrong way round, it goes inside the camchain pointing out.
Offline Mo
« Reply #28 on: September 23, 2012, 07:06:22 AM »
I think I have that right.
Cam Chain Tensioner & Guide
Offline luap
  • LAWL
« Reply #29 on: September 23, 2012, 08:30:50 AM »
+1 was the chain riding on the inside an not in the middle
Pull the chain tight an cycle it does it make noise
www.cb-town.com
Offline mickwinf
« Reply #30 on: September 23, 2012, 09:21:21 AM »
hmm video didn't realy help. if you imagine the chain in a loop, the main tensioner presses from the outside of the loop, the guide presses from the inside of the loop. And yes the main tensioner does locate in a slot at the bottom with a little locating piece, make sure that it is in place.
Offline Mo
« Reply #31 on: September 23, 2012, 10:04:26 AM »
Okay so. I rebuilt it again, making sure everything was carefully put in place and that seemed to solve my problem with the cam chain noise (completely silent now).
BUT: When the valve cover is off, the kickstart turns the engine fine (a bit of resistance though). When the cover is on, the kickstart still on partially turns the engine, and then locks. Turning it over via the bolt frees the kickstarter again.
WTH?
Offline Mo
« Reply #32 on: September 23, 2012, 10:39:44 AM »
A theory perhaps: When the cover is off, its still pretty hard to turn via the kickstart using my arm. When I put the cover back on, could I be getting "stuck" when multiple springs are being compressed and I am just not pushing it hard enough?
I know this would be easy to test, but I don't wanna use too much force and break something. What should the level of resistance here be?
Offline luap
  • LAWL
« Reply #33 on: September 23, 2012, 12:18:25 PM »
did you try cracking all the rocker adjustment screws? those at this point should be your only resistance. Im no expert but if the kicker cycles w/o cover on no resistance on valves put the cover on an kicker doesnt cycle to much resistance on vavles crack adj screw shouldnt be any resistance on valves then gap them
www.cb-town.com
Offline LesterPiglet
  • 1977 CB550F2
« Reply #34 on: September 23, 2012, 12:29:34 PM »
Are any valves bent? It can be easily done reassembling if you haven't done it before.
Offline Fritz
« Reply #35 on: September 23, 2012, 04:20:14 PM »
My guesses:
- The bottom of the cam chain tensioner was not sitting in its groove in the engine case, rubbing on the primary chain. You seem to have got that right on your second rebuild.
- The cam shaft is not correctly aligned, making your pistons hit the valves or
- You did not pay enough attention when putting on the valve cover. Rockers or valve adjustmend screws interfered with some of the valve stems, bent them and trashed their valve guides.
Recheck your cam timing and put a straight edge on the valve stems. A bent stem will point a little bit outwards.
1976 CB550F
Offline Mo
« Reply #36 on: September 23, 2012, 04:31:29 PM »
Okay well I think I got it now. I'm not really sure, but it seems like adding some more force on the kick worked out. I mounted it back onto the bike and it seems like its pretty smooth kicking over.
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #37 on: September 23, 2012, 09:42:48 PM »
Oh man, getting the bottom of the cam chain tensioner installed right is a pain and a half! I wrestled with that stupid thing for a week!
Here's the tricks:
1) Don't put the cylinder in and the tensioner- hold the cylinders about an inch or a bit less up off the crank case, put the tensioner lock bolt through the hole, then drop the whole thing down nice and easy.
2) Pop the oil pan off and see if you can the bottom of the tensioner, it's not in the right spot. Dave schools me on this about halfway down this page: http://forums.sohc4.net/index.php?topic=110973.100 Look for the post with the schematic.
Good luck!
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
