Author Topic: New accelerator pump diaphragm destroyed  (Read 2367 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: September 22, 2012, 12:07:37 PM »
From Parts n' More. My old one was falling apart so I ordered this replacement for $18 (+ $12 shipping!!) Popped it in yesterday and I still wasn't getting anything out of the nozzles, or through the pipes connecting the carbs. I've already thoroughly cleaned that entire circuit, including pressing out the nozzles themselves and running a guitar string through. Also proved with compressed air.
So has anyone else had this problem with these replacement parts? Is it the ethanol in the gas? Hard to believe that it would destroy the rubber so quickly, but look at how distorted the thing is!
Offline lucky
Re: New accelerator pump diaphragm destroyed
« Reply #1 on: September 22, 2012, 05:50:57 PM »
It is not the diaphram causing it not to work.
It is the check ball in the bottom pump plate.
« Reply #2 on: September 22, 2012, 06:20:23 PM »
Hey Tug,
Is the rubber on the diaphragm gooey, like it is being dissolved?
If so, that's the ethanol.
bollingball
« Reply #3 on: September 22, 2012, 07:01:13 PM »
Tug I have to say I have not seen one like that. I am thinking 3 possibilities. Chemical (TT) or mechanical you did not have it lined up and pinched the two parts that are separated? Or it has to be the most inferior part ever made. ??? I have had all sorts of gas in mine and never seen any thing like that. Are you saying it is only a day or two old? Very very odd.
Ken
Offline fmctm1sw
« Reply #4 on: September 22, 2012, 07:13:48 PM »
pressing out the nozzles themselves and running a guitar string through. /218185_10151182830364181_971933811_n.jpg[/img]
If you don't mind me asking, how did you get those nozzles out?  Sorry to hear about the fault..
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
bollingball
« Reply #5 on: September 22, 2012, 07:17:40 PM »
They pull out like the press in slow jets but not as easy to get back in. You have to line them up with the hole in the choke butterfly so they shoot straight.
Ken
« Last Edit: September 22, 2012, 07:19:46 PM by bollingball »
« Reply #6 on: September 22, 2012, 07:18:25 PM »
Ken
My thoughts as well; 10% ethanol shouldn't do that in such a short time. I once dropped a rubber band in some "real" gas once, and was amazed about how swollen and gooey it was the next day.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #7 on: September 24, 2012, 10:15:34 AM »
Yeah, it was exposed to gas for less than 24 hrs. Rubber doesn't feel gooey necessarily, and once it dried out it regained its original shape. Very weird. There's only one way for it to fit in the bowl, and like i said, it doesn't move enough to have "ripped" so it must have just been a bad one. Hopefully the replacement doesn't have the same defect.
About the nozzles: Spanner1 turned me on to the fact that you can press them out. I used adjustable pliers with some electrical tape on the jaws to keep from marring anything. The jets press out, as do the brass bungs, and you can clean them and press them back in with a punch. Make sure the passageways line up upon reassembly! You'll see what I mean when you get it all apart.
And yes, I'm going to double-check the check valve to make sure it's working correctly.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #8 on: September 25, 2012, 09:11:26 AM »
So three emails over the past three days to Parts N More - no response, and there is no phone number or other means of contacting them. Sux.
« Reply #9 on: September 25, 2012, 09:20:44 AM »
crazy that it swelled up like that  :o no wonder it wasnt squirting.  did the holes in the mikey mouse ears all close up? hope parts-n-more gets back to you.
while you've got your carbs on the bench, check to see that the brass restrictors are in place inside the tubes between the accel pump squirters.  only pull the squirters out if they're clogged.  i put a nice bend in some wire to get the squirter holes cleared so i didnt have to mess with pulling them and ruining something.  compressed air and carb cleaner to spray through them helps.
ultrasonic+simple green and compressed air were the best way to clear the check ball in the bottom accel pump plate.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #10 on: September 25, 2012, 10:07:26 AM »
Response from Parts N More:
It appears that carb cleaner must have got in contact with the diaphragm. You will need to purchase a new kit.
Regards
PNM
« Reply #11 on: September 25, 2012, 10:40:16 AM »
Regards
PNM
SERIOUSLY?!?!?   :o  Not the response I was hoping from them.
Offline lucky
« Reply #12 on: September 25, 2012, 05:37:20 PM »
I do not like  it either.
