Author Topic: Opinions on electronic ignition upgrades?  (Read 7096 times)
Re: Opinions on electronic ignition upgrades?
« Reply #25 on: September 27, 2012, 07:27:03 PM »
have another look at the specs for the boyer micro power hondaman,the coils draw less than the stock ones in use,the average consumption is less than 1.5 amps.
Do you have a good place for me to look? The last time I used them was about 11 years ago. Maybe their design changed? At that time, they used the stock OEM coils or the 3-ohm coils from Dyna/Accel, hence the high current draw.
« Reply #26 on: September 27, 2012, 07:29:51 PM »
Amps? Watts? I'm confused.   :o
The alternator on the bikes are rated in the watts they produce: it is pretty easy then to add up the lamp wattage (40w headlight, etc.) and the overall total ignition draw(s). Then you don't have to convert the alternator watts to amps, then add up the amps, wondering if the battery is at 12 volts or 13 volts, etc... :)
I'm lazy, as most engineers are, in this sort of calc.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #27 on: September 27, 2012, 07:32:44 PM »
+1 for the HM unit. I installed one last year, and I just got my first look at the points after 2700 miles. No wear, no pitting, they look just like they did a year ago. Palpable performance upgrade as well. Mark does a great job at a very reasonable price with that unit. (I'm using Dyna 5k ohm coils).
« Reply #28 on: September 27, 2012, 11:56:02 PM »
yeah the modern unit uses digital coils wired in series,with the 55 watt headlight on itll easy charge 14 at 2500-3000
Offline wardenerd
  • '77 550F '81 650C
« Reply #29 on: September 28, 2012, 05:01:06 AM »
I have an accent set up from Germany it appears to be the same unit in the picture.  Improved cranking, idle and performance.  I have had it only about 6 months.
Offline Rgconner
« Reply #30 on: September 28, 2012, 07:58:03 PM »
If you use stock Honda coils:
The extra load from my unit is 1.2 watts.
Shoot, you could lose that much and more from a single dirty connector.
1975 CB550K aka "Grease Monkey"
