Author Topic: rear axle shaft hard to drive all the way through hub  (Read 1004 times)
Offline dhall57
« on: September 25, 2012, 06:27:40 PM »
Here's some pics. Got my new rear wheel bearings on my 750KO in and everything looks good. But something must not be right. When I go to push the axle through it does fine until it starts coming out the other side. Than it gets to where I can't push it any further by hand and I have to get a small hammer and tap it the rest of the way. Should I have to do this? With old bearings I could push axle in or pull axle out by hand.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
Re: rear axle shaft hard to drive all the way through hub
« Reply #1 on: September 25, 2012, 06:34:33 PM »
I usually find the same thing. It may be that the spacer is slightly misaligned. Shouldn't be a major problem. Have you applied a little grease to the axle itself?
« Reply #2 on: September 25, 2012, 10:05:17 PM »
Very normal. The inner tube usually misaligns a tad, then straightens up after the axle is thru. I always grease the axle, that way it will always be better next time. ;)
Offline hoodellyhoo
  • CB350F
« Reply #3 on: September 26, 2012, 04:56:01 AM »
+1 I greased mine a little too
