Author Topic: 78 CB750F "Modular-ish" cafe build?  (Read 59434 times)
Offline madScientist
Re: 78 CB750F "Modular-ish" cafe build?
« Reply #125 on: June 04, 2013, 10:49:08 AM »
I'll get a picture of the CycleX oil cooler adapter tonight. It's nice because you can use it with an oil cooler or without by removing / adding allen screws. Just make sure you use teflon tape.
Do you use any particular flavor of ZDDP additive? I run Rislone in the 66 stang however I was thinking of switching to Redline. I fell in love with their assembly lube.
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline sethdhawkins
« Reply #126 on: June 04, 2013, 10:52:46 AM »
I figure any zinc additive is better than nothing. I ran some Lucas stuff, and am now running the ZDDP. I think it's like oil preference ;)
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
« Reply #127 on: June 04, 2013, 11:41:09 AM »
Oh gosh lets not get started on an oil thread....
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
« Reply #128 on: June 05, 2013, 12:59:40 PM »
Started on the improved oil cooler mount patterned off of Branden's design. I'm about 80% done with it and will post up some pictures when it's done. Another big thanks to Branden for sending detailed photos of the mounts. I was having a difficult time envisioning a way to hang it up there.
Probably wont be able to work on it over the next few days...day job is starting to get in the way.
Here are a couple photos of the cycleX oil cooler adapter. I tried to get a shot from underneath but didnt turn out real well. I dont really like how close the lines are on the adapter. I'm going to run L plugs in and then an adjustable L plug out into stainless braid to a 45 degree plug at the cooler.
TOP
From underneath
« Last Edit: April 10, 2014, 05:41:03 AM by madScientist »
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
Offline MOONDOGNYC
  • BLOOD, SWEAT AND GEARS
« Reply #129 on: June 05, 2013, 05:16:36 PM »
Very cool....
1977 CB750F
Offline Sixgunsrattlesnake
  • Blue Collar Renovator
  • SEMPER PARATUS
« Reply #130 on: June 07, 2013, 03:22:42 PM »
Just stumbled upon this build... I like the Modular Idea. In fact I did a similar thing myself. In less than 30 minutes I can switch from a low hardtail bobber with a solo seat back to a more stock-ish style of cb... It wasn't intended as such, but it has worked out to be two bikes in one. Bolt on struts and seat and a bar swap.
"He wore his gun outside his pants, for all the honest world to fear."
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
« Reply #131 on: June 07, 2013, 06:40:30 PM »
I dig it man! I really like that high back bar. I have a similar one that I made out of rebar on the tail of the Zuke 1400.
I want to do essentially the same type of thing.  I want to be able to run cafe style for commutes to work and such but when I go on long hauls I can put a corbin gunfighter on there and not lose my a$$.
I'm not sure the wife is going to ride this one with me. She heard it fire up and said "it sounds scarier than the 'truder". I'll take that as a compliment I guess :-D
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
« Reply #132 on: June 07, 2013, 06:54:10 PM »
Nice! A reference to Poncho and Lefty?
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
  • SEMPER PARATUS
« Reply #133 on: June 07, 2013, 06:56:25 PM »
My "bobber" was cool for bar hopping. It gets a lot of...uhhh...Compliments? Gets a lot of questions thats for sure. But its a pain for anything longer than 20 miles and highway performance blows. But if I keep things going the direction I am, in 30 minutes I can switch between the two. Compatibility baby... The wife gets a ride too. But its been a battle between my current seat and she wants one of those god-awful fat ended king/queen jobs....
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
  • SEMPER PARATUS
« Reply #134 on: June 07, 2013, 06:56:49 PM »
yessir
1993 CBR600F2
1978 CB750K
1978 XS400S
1978 CM185T
1971 CB350K
« Reply #135 on: June 09, 2013, 03:33:40 PM »
The best laid plans of mice and men...
The brakes are bled up and working. I made a bracket for the R6 brembo rear master that's essentially a kidney bean made out of weld steel but it works. I want to clean it up and probably give it a shot of gloss black. The Nissin front unit is mounted up, bled and works nicely.
Rolled it out and got the carbs all sync'd up. It's amazing how little clacking those carbs make when they are in sync and set at about 1400 rpm. I dont see any leaks which is fantastic!
and then it started to rain :-(
Oh well...i have it ready for the test ride when the weather clears up. Here are a couple shots in the garage. She needs a little cleaning too...
« Last Edit: April 10, 2014, 05:41:21 AM by madScientist »
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
Offline MOONDOGNYC
« Reply #136 on: June 09, 2013, 04:45:28 PM »
Looks AWESOME !!!!!
1977 CB750F
« Reply #137 on: June 09, 2013, 09:20:23 PM »
Better than snow!!!! Looks wicked.
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #138 on: June 10, 2013, 05:28:35 AM »
Thanks guys! There are still a few little things to do but nothing stopping me from riding it.
I'm hoping I'll get a chance tonight after work.
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
« Reply #139 on: June 10, 2013, 06:14:37 PM »
Took her out for a slow jaunt this evening. Two things are abundantly clear
1) there is still air in the rear brakes
2) the engine has surpassed the capacity of the clutch that is in it.
 would hit about 3000 rpm and it would let go. I think the springs are weak as it felt real easy working the clutch.
Anyone have recommendations on plates and springs?
Other than that it ran and handled great! Surprisingly comfortable even with no padding.
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
« Reply #140 on: June 10, 2013, 07:04:35 PM »
APE engineering has a better clutch with stock feel at the bars... ;)
http://cbrzone.com/sohc.html
3/4's the way down the page, everything on that page is for our bikes.... ;)
« Reply #141 on: June 10, 2013, 10:36:08 PM »
Wow, your mill is either a real fire breather, or you have some super weak springs ;) I'm hoping it's the former! As Retro said, a set of those HD springs will be the ticket. I noticed no increase in lever feel. Putting the plate on is supposedly Pandora's box, so be careful.
I can't wait to see more pictures!!!
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #142 on: June 10, 2013, 10:44:44 PM »
Actually Seth, the springs are similar to stock in the Ape clutch, its the extra plate that does the trick.... ;)
« Reply #143 on: June 10, 2013, 11:20:22 PM »
Ahh, gotcha. I didn't read into it too deeply, I just assumed they were the HD springs like the Barnetts. Glad you set me straight!
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #144 on: June 10, 2013, 11:38:22 PM »
The Barnetts were a bit "on and off" and had a heavier lever, these ones APE have don't do any of that.... ;)
« Reply #145 on: June 11, 2013, 05:26:11 AM »
Should I start with the springs and get the discs if I need them or get the whole ball of wax? I changed out the discs back in 2008 (i think) because the originals disintegrated.
This next one might stir up a hornets nest but...I run Mobil1 in all my machines that dont get AMES. That being said, could that be attributing to some of the slippage? I hear these older bikes prefer conventional.
And new updates...last night I rode it up to the fuel station and put about 3 gallons of gas in it. This morning I was awoken by the smell of gas wafting through my house. The bike is living in an attached garage and when I went out to check on things I was met with the site of probably 2 gallons of that gas on the floor  >:(
I swore I set all the floats at 17mm however it would seem I didn't get the #2 float set properly as it's got a slow -> steady dribble out it's overflow. Is it possible to drop the bowl, adjust the float, and reset the bowl with the carbs on the bike or do they have to come off?
I had the petcock in the "off" position and had rebuilt it. Is there anyway I could have put it together backwards or wrong? Is it possible to fit one from a different bike since the F petcocks seem to be made from unobtanium?
I'll poke around the search feature and see what I can dig up but any help would be appreciated. I'm a tad frustrated but eventually the kinks will get worked out.
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
« Reply #146 on: June 11, 2013, 06:16:07 AM »
Ordered Part #: 20-8037 from vintagecb750.com. According to the description that petcock should fit the F tank with the exit being oriented towards the rear instead of aimed at the carbs.
Hopefully that is the case and it fits...
Next up...fix the carb drainage and rear brake...
EDIT
I just realized the APE kit is the discs, plates, and HD springs...and it's about $100 which was less than the kits from Dynoman. So I'm going to give it a crack!
What's your all's opinion on the oil and fixing the carb float level on the bike?
« Last Edit: June 11, 2013, 06:20:23 AM by madScientist »
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
Offline Bankerdanny
  • Endeavor to persevere
« Reply #147 on: June 11, 2013, 08:50:06 AM »
Asking for opinions about oil is very very dangerous, plus it kills puppies.
But since you asked. Running any car oil is not a great idea, and running synthetic car oil is even less of a great idea. Car oils are designed for maximum slipperiness, great for the inside of an engine, not so great for a clutch.
Conventional motorcyle oils however are designed to work with shared engine/clutch systems. If you ride in really hot weather and so like the idea of synthetic then just make sure it is both motorcycle specific and for wet clutch systems.
« Reply #148 on: June 11, 2013, 09:10:00 AM »
Yeah I was REALLY leery about asking an oil related question but like the opinions :-D
I'll double check on the Mobile1 synth oils to see what it says. Thanks Danny!
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
« Reply #149 on: June 11, 2013, 03:15:41 PM »
EDIT
When you order the clutch, tell the guys that you are a member of this forum, I am sure there is a forum discount.... ;)
