Author Topic: recommend a lift/stand?  (Read 1025 times)
Offline jason41987
« on: September 29, 2012, 04:59:18 PM »
i was wondering if someone could recommend a lift/stand to get a bit of distance between the bike and the ground, starting to become a pain in the rear to constantly bend down to work on this with my neck issues...
so can someone recommend a good solution?.. probably need something more than the 16" jacks which seem to be used for little more than taking wheels off
Offline toytuff
  • "watching the pinheads"
Re: recommend a lift/stand?
« Reply #1 on: September 29, 2012, 05:01:19 PM »
Foot operated lift table from Harbor Freight. $299.00 with coupon.
tt
« Reply #2 on: September 29, 2012, 05:13:39 PM »
If your on a tight budget you can also make a ramp/stand out of some scrap lumber to get the bike up higher.
Offline jason41987
« Reply #3 on: September 29, 2012, 05:28:30 PM »
so with the table lift i could notch a couple planks of wood to support the frame of the bike and lift it by the frame rails uinder the engine that way?
