Author Topic: Hello from Oklahoma!  (Read 540 times)
Offline Goosiejuice
« on: October 01, 2012, 08:30:56 AM »
Hey all, I've been lurking around for quite a while, and I figured it was time to make my first post... I bought my first CB a few months ago, and the addiction struck in full force. I paid $200 for a 1976 CB750K6, that at the time was not running, and had been sitting in a guys garage for the better part of 15 years. He had apparently bought it himself, ridden it for two weeks, and the engine promptly "locked up" (as per his words) and he never could get it running again.
I brought the beast home on a trailer, once home I tried kicking it over and amazingly... it was locked up. So, I began looking for a cause to this; pulled the side covers and everything looked kosher. Finally I remembered a, older Chevy I had the displeasure of diagnosing at one point and the idea was so simple it was stupid; the starter. Pulled the starter motor out and lo and behold, the gear was locked out. Gave her a kick and it turned over!!! Promptly sputtering, coughing, and protesting its' rebirth, it backfired and blew off one of the pods the PO had installed. From there, I did the obligatory ritual tune up (turns out the coils wires were swapped so it was firing on the wrong cylinders AND the valves were set with the crank 180 degrees out), cleaned the carbs, rejetted it for the pods (yuck) and open 4-2 exhaust, replaced the battery, tires and the lights. Gave her a short kick and about halfway through, she fired up and idled away!
Fast forward a few months and about 7000 miles, I've ridden it with the expectation that a full motor rebuild may at some point be a reality, as I don't know what all was done by the PO in an attempt to get it running... I've rewired it, leaving only the necessary items (sans starter, winkers) due to the PO's butchery of the harness, and enjoyed the hell out of it. However, last Thursday I was riding it home and about two miles from home, on the highway, in traffic, with no shoulder to pull onto... I begin to hear an occasional "whump" sound from the motor at around 5k. Soon, (read, near immediately) the "whump" became a ratcheting sound, and the rear tire locked up. Luckily I was able to keep it out of a slide, and made it to the turn-off to my house. Proceeded to push it the rest of the way home and park it. After reading up on the symptoms, and other members with similar problems, it sounds as though the dogs in the transmission have probably sheared off to some degree... My issue sounds exactly like http://forums.sohc4.net/index.php?topic=59158.0. So, it looks like in the name of reliability and safety for the beast, I'll be giving her the full treatment. I'm including a before and after of what it looked like at purchase, and what it looks like (a couple additional visual enhancements not included) at the current moment. I'll be pulling the engine this weekend.
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Hello from Oklahoma!
« Reply #1 on: October 01, 2012, 08:47:47 AM »
Welcome, and good job at getting her back to life and quickly figuring out the out-of-phase ignition and valve timing.  I'm sure you'll be able to rebuild the engine/transmission with no major issues.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Big_e78
« Reply #2 on: October 01, 2012, 09:12:21 AM »
Best of luck to you. I look forward to seeing another 76 on these Oklahoma roads soon!
