Author Topic: Clutch Adj. CL360  (Read 721 times)
Offline sohcphreek
Clutch Adj. CL360
« on: October 03, 2012, 08:40:36 AM »
HELP!
Working on my buddy's 75 cl360, it has been siting for awhile got it running great but can't get the clutch to stop slipping on hard acceleration. bike only has 4k miles and he just bought it. went by the haynes instruction manual and then backed the main adj screw way off and snuged it up with no results now when you pull the handle in it has a clunk like the rod is slipping out of place or something.
IDK whats going on, Any help ?
thanks sohcphreek
Offline Shane72
Re: Clutch Adj. CL360
« Reply #1 on: October 03, 2012, 06:30:26 PM »
You'll want to take off the cover that houses the clutch cable-clevis connection.
That little sucker has a lot of force on the split end, and I've found that if it starts to spread out at all, it will clunk as described.  When it gets a little more spread out, it can stop disengaging the clutch altogether.  Best to remove it, take it to the vise, and peen the rivet back over the open end.
It's not the best design...
As far as the slipping goes, I'd disassemble the ramp and ball system, along with the little steel ball bearing (don't lose it!) that resides in that same cover.  Clean it all, grease, then reassemble.
The clutch may still slip, but it's best to first make sure that all of the potential things that can hang it up are serviced first.  There are a lot of moving parts involved, and they do get quite nasty over the years.  It wouldn't hurt to make sure the cable itself is totally free-moving as well.
If it still slips after all this and a proper adjustment, well, enjoy the new clutch...
All the best,
Shane
I mount and balance MC tires--while-you-wait service by appointment.  Send me a PM.
Offline sohcphreek
« Reply #2 on: October 08, 2012, 09:16:43 AM »
Shane,
thanks for your time and knowledge! I will be working on his bike some time this week or next. This bike shows extremely low miles on the clock and has been sitting along time. Cleaning and grease sounds good, let you know the outcome
Chris
Offline Shane72
« Reply #3 on: October 08, 2012, 06:19:36 PM »
Good luck!
Shane
Offline sohcphreek
« Reply #4 on: November 18, 2012, 08:45:19 PM »
well
still slipping and cleaned the side cover completely with new grease.
Guess I have to go into the plates/springs etc.. be more into it if this was my bike!!
Chris
