Author Topic: cb400f clutch bearing replacement?  (Read 635 times)
Offline kyre
    • CB400F / 466 Build Thread
« on: October 04, 2012, 08:09:00 PM »
I've been looking around but can't find how to remove the bearing from the clutch lifter plate so I can replace with a new bearing. #130 needs to be removed from the inside of the bearing and #121 needs to be removed from the outside. Do I need to press them out?
CB400F / 466 Build Thread (currently in progress)
http://forums.sohc4.net/index.php?topic=105027.0
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
Re: cb400f clutch bearing replacement?
« Reply #1 on: October 04, 2012, 08:45:40 PM »
Kyre,
Dunno about the 400f difference to 750 - but my 750 lifter plate bearing almost jumped out at me. Not held in like any "mother stuck" bearing I've encountered. I just warmed the plate over with a hot air gun, held it up at eye level to decide whether to push, pull and it fell out. I bought a replacement lifter plate and the bearing just fell into the hole of that plate without use of hammer, puller, screwdriver or alcohol.
Hope yours is as obliging.
Mark
Offline kyre
« Reply #2 on: October 05, 2012, 04:21:34 AM »
Well that's the problem, I tried heating it up but it won't budge and this bearing is shot. A friend has a press which I'll try this weekend, I just don't want to bend or break anything.
« Reply #3 on: October 05, 2012, 04:25:28 AM »
the old one will knock out ok,if you support the housing and use a socket that fits the outer of the new bearing but clears the housing youll be able to knock the new one in fine.
