Author Topic: Running lean on one cylinder: 83 GL1100  (Read 2456 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: October 08, 2012, 09:29:57 AM »
Took my new (to me) bike out on Friday afternoon for a lil' 100-mile jaunt. It is running lean on the cylinder closest to the fuel pump. At over 1/2-throttle it's better, but from closed up to about 1/2 it is lean. Backfiring, gurgling on deceleration. I'm assuming that it is a clogged slow jet... but is there anything else that could be causing that on just that one cylinder? New to 'Wings, so that's why I ask.
Re: Running lean on one cylinder: 83 GL1100
« Reply #1 on: October 08, 2012, 09:58:59 AM »
I just went though and refurbished the carbs on my 81 GL1100I.
These carbs are more complicated than any MC carbs I've worked on.  You can thread tap the end of the slow jet for 4-40 put in a screw and then pull the slow jet out by pulling on the screw.
Don't overlook the air cut off valves.  I'm not certain it will cause your direct problem description.  But, all four of mine had dissolved in today's ethanol gas (as well as 3 of four idle jets clogged).
These are CV carbs, so the vacuum lift may also be an issue, as the carb tops are size matched to the pistons which do the lifting.  They must be replaced as mated pairs and not swapped around with other components.
I went with Randakk's complete rebuild master kit.  All the rubber is replaced with Viton which will withstand ethanol gas without deterioration.
Mine ran on two (poorly) before the ohaul, IF you kept blipping the throttle to keep above 2K RPM.  After ohaul it idled and ran well on all four.
On yours, you might try a carb synch before digging into the carbs.  The cylinder closest to the fuel pump is # 3 and is the master carb with no carb sync adjustment.  Perhaps, the last carb sync wasn't done correctly?
Offline Peterbylt
« Reply #2 on: October 08, 2012, 11:09:59 AM »
If it is an 83 and has the 83 carbs then the Idle jet on the carbs will be rmoveable.
80 nand 81's are pressed in.
Try running some seafoam through them. Good results have been reported.
Peter
1975 550F SuperSport
1975 GL1000 Goldwing
1979 CM400A Hondamatic
1981 GL1100 Goldwing
1985 CMX250C Rebel
