Author Topic: air/mixture screw with hole  (Read 1216 times)
Offline DYSKORD
« on: October 09, 2012, 01:28:48 AM »
So curious about the mixture screw with hole. Some say to JB Weld it. What are the experts opininions? Should they be replaced with solid type, close up, or leave as is.
Re: air/mixture screw with hole
« Reply #1 on: October 09, 2012, 02:10:46 AM »
i like solid ones,you cant enrichen past a cetain point with the drilled ones,they are akin to those idle mixture limiter caps you used to get on smog cars with carbs,i use solder.
Offline SOHC Digger
  • I'm not an
« Reply #2 on: October 09, 2012, 04:07:57 AM »
I have used solid ones if you are interested.
Offline aperry
« Reply #3 on: October 09, 2012, 04:33:17 AM »
Pretty sure I read a comment from Hondaman (in another thread) indicating that you shouldn't fill these holes.  Apparently the carbs that came with solid screws had other changes designed to accommodate the air flow properties of solid screws.  I played around with this in my pod setup and found that it made things even worse.  Ultimately larger idle jets really made the difference.
CB750K3 with F1 frame/swingarm
Offline lucky
« Reply #4 on: October 09, 2012, 06:32:29 AM »
I always wonder why some are so reluctant to change idle jets. ???
« Reply #5 on: October 09, 2012, 01:46:18 PM »
their not hard to solder,it can cure a soggy cold blooded hard to start engine,even with the screw all the way in and closed the drilled type still pass air.
Offline DYSKORD
« Reply #6 on: October 10, 2012, 01:37:57 AM »
This whole thought process was the result of noticing lean conditions once the screws were richened up past a certain point. Bigger pilots are on order. There is no question the bike is running on the lean side (K&N pods, Yoshi open exhaust and cycle x ignition, 125 mains up from stock 105), but I found it weird that when adjusting the mixture, it would seem to richen up right before it got a bit leaner. Never getting as rich as I would have liked. Possibly my imagination as well.
42pilots and 130/135mains on the way, I guess I could give the solid mix screws a shot.
« Reply #7 on: October 10, 2012, 03:06:34 AM »
solder the pods up and find a baffle.
