Author Topic: CR750 brakes - opinions  (Read 10426 times)
Offline Artracing
Re: CR750 brakes - opinions
« Reply #50 on: November 29, 2015, 10:50:55 AM »
The Ceriani top tree has a lot of height.. Hard to make a billet one look even close..
 Are you firmly stuck on wire heels .. I know of a mag that has the MOST clearance..and they are reasonable.. And come in 18 and 19 inch
I would be interested to know on 18. Thank you.
Rob
« Reply #51 on: November 29, 2015, 10:56:21 AM »
Well then just build your own narrow 6 bolt hub.. Can be made in under 10hrs on a manual lathe..
 I think the narrower width where spoke heads sit, may be less ridgid than a wider hub..
70,s Ysmaha mags..i squeezed a 6 piston caliper into a Ceriani GP fork using that wheel..320? Rotor I think.. Will try to post a pic later.
« Last Edit: November 29, 2015, 11:02:34 AM by 754 »
Offline BPellerine
« Reply #52 on: November 29, 2015, 04:49:03 PM »
just curious did you get a speedo drive on that setup?billp
1978 CB 750K ard and webers
another anfob
« Reply #53 on: November 29, 2015, 05:57:49 PM »
I think not but there may he room...I did it for the chopper and he never finished the bike yet.
