Author Topic: Clutch Slave Cylinder rebuild  (Read 885 times)
Offline Sch43547
« on: October 10, 2012, 01:47:45 PM »
Alright guys. I have a tricky one for ya. I am rebuilding my slave cylinder and boy was it pretty nasty. But I want to be sure I put it back together correctly. Therefore, my question is, do I grease up any certain areas before I put it back together? If you have any idea on what I need to do please comment below a process.
(The picture below is missing parts that I am currently waiting on.)
(The nastiness before I cleaned it up)
Offline Killer Canary
  • Typical Bran Muffin
Re: Clutch Slave Cylinder rebuild
« Reply #1 on: October 10, 2012, 02:36:12 PM »
If there's any discolouration in the bore, it's a good idea to lightly sand it with #600 (around the diameter, not in and out) as a brake hone would be too aggressive on aluminum. Other than that it's to make sure the seal is good and to apply a light coat of brake fluid to it and the bore when re-assembling. I'd gladly trade the whole mess for a cable actuated myself.
Kawi GPz900, H1
Offline Sch43547
« Reply #2 on: October 10, 2012, 02:44:23 PM »
So no grease used anywhere?
« Reply #3 on: October 10, 2012, 03:21:16 PM »
 Maybe on the actuating rod where it contacts in the cases. Pull it out and have a look.
Kawi GPz900, H1
