Author Topic: Can valve cover leak cause lean con...  (Read 1871 times)
Offline fdbrat
« on: October 10, 2012, 07:30:11 PM »
Hello guys.
Can a valve cover leak cause lean condition?
Stock all the way around. Problem is when snaping the throttle it seems to take longer than normal to return to idle.
Any help that would be great.
I got this bike for $50. Pretty stoked. Got it running in one day. : )
1975 CB750F
4-4, Dyna S and box
5 ohm coils / 5k ohm caps
In- .05 / Ex- .08
San Luis Obispo
Offline Dimitri13
  • 1974 CB550K
Re: Can valve cover leak cause lean con...
« Reply #1 on: October 10, 2012, 07:31:08 PM »
No. Check for air leaks around the intake manifolds, carb boots, and exhaust leaks.
Offline fdbrat
« Reply #2 on: October 10, 2012, 07:38:04 PM »
Pix are fun..........So here is one?
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline fdbrat
« Reply #3 on: October 10, 2012, 07:44:03 PM »
I patched up a bad leak on pipe 2 just before the collector.
So pipes are sealed. No major rust, nothing a little steel wool can't fix.
What about a cracked smog hose going to the air Box.
It's dark so I can't mess with it now. Looking for ideas.
What's the best way to look for leaks?
And no back fees. It's off the DMV records. And not registered stolen. So I can take my time on his one. : )
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline Dimitri13
  • 1974 CB550K
« Reply #4 on: October 10, 2012, 07:57:14 PM »
The breather hose wouldn't cause it either.
Spray WD-40 around the manifolds and boots. If the revs go up, it's got a leak.
Offline fdbrat
« Reply #5 on: October 10, 2012, 07:59:29 PM »
Thanx brudah. I'll report back in the tomorrow.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
« Reply #6 on: October 10, 2012, 08:00:49 PM »
You can look for leaks with starting fluid, Gumout spray, WD40 or a propane torch with the flame off of course. What you ar looking for a change in idle as yo spay one small part at a time.
Alsom under the rubber grip is a plastic sleeve that contacts the handlebar. The old grease dries out and dirt and crap builds up. You can clean that and lube it with Silicone or Teflon dry lubricant.
If the cables are old, as they wear little broken strands form whiskers that rub on the cable sheath. You can spray some lube in and if it improves it will be short term and you need new cables.
Offline millerza
  • Zach Miller
  • 750K8 fixing rebuild probs
« Reply #7 on: October 12, 2012, 07:41:38 AM »
That headlight looks hilarious, like it pissed off that guy from Beetlejuice  .
« Reply #8 on: October 12, 2012, 08:06:13 AM »
Maybe I missed it, but does the throttle have some play in it? Should be able to rotate the twist grip 1/16 of a turn, indicating some slop in the cable, which is what you want.
If no slop, you could get the symptom you describe. There are adjusters at each end of the cable.
Offline phil71
« Reply #9 on: October 12, 2012, 09:48:37 AM »
Air leak or bad sync can cause hanging .. Do the 3000 mile tuneup
« Reply #10 on: October 12, 2012, 08:18:49 PM »
Might have something to do with that massive air scoop on the front. Ingenious.
bollingball
« Reply #11 on: October 12, 2012, 09:00:34 PM »
I think that is for in flight fueling.
Ken
Offline fdbrat
« Reply #12 on: October 12, 2012, 09:13:54 PM »
The ram air you are all joking about is an aux gas tank, aka funnel. The tank could use a good coating.
It's been raining and I haven't been able to work on the bike. I just got new press in jets in the mail. So as soon as I get it running god stock, I can make some changes.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
