Author Topic: CB350 carb question... rubber plugs on slow jet?  (Read 2413 times)
Offline Celco
« on: October 13, 2012, 10:03:13 PM »
Working on a bike for a friend.  Have played with many 550's and 750's, but this is my first time for a 350.  Curious about these little black plugs that go on the slow jet.  This rubber on this bike is more like plastic and don't know if these plugs should be bopping around the hole loose, or fit snug like a real plug.
Found replacements, but unsure if I need them or if I can reuse the hard ones that dont seem to "completely" seal off the passage.  Guess SCI is calling them rubber passage plugs.
What is the deal on these bad boys?
EDIT* Should say these are the CV carbs from a 72 CB350
« Last Edit: October 13, 2012, 10:13:25 PM by Celco »
Offline CBGBs
    • Ride or Rot vintage motorcycle event in FTW
Re: CB350 carb question... rubber plugs on slow jet?
« Reply #1 on: October 14, 2012, 07:08:24 PM »
Those things seem to serve a non critical purpose. If they are falling out for sure, I would replace them. I don't think I've run without them but I'm sure I have used hardened plugs.
'66 CB77 Superhawk  '73 CB350G Cafe  '75 CB400F '65 S90  '78 CB750 SS
Offline fmctm1sw
« Reply #2 on: October 15, 2012, 05:29:30 AM »
Over on the CX500/Silverwing forum there is a picture of an exploded carb that will show you exactly how that works.  I'm short on time or I'd find the link...
http://cx500forum.com/index.php?/topic/17090-what-happens-if-you-take-the-plug-out-of-the-slow-jet/page__p__198227__hl__%2Bidle+%2Bjet+%2Bplug__fromsearch__1#entry198227
« Last Edit: October 15, 2012, 11:10:28 AM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
