Author Topic: Head light hole  (Read 880 times)
Offline Paul Lowe
  • If you like then it is good...
Head light hole
« on: October 14, 2012, 12:54:44 PM »
Can anyone tell me what the hole on top if the headlight is on a CB350F is for. Has black plug in it now.
My Honda sickness deepens
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
1/2HP electric bike home made...
Offline Bluegreen
Head light hole
« Reply #1 on: October 14, 2012, 02:38:49 PM »
High beam indicator ?
Offline millerza
  • Zach Miller
  • 750K8 fixing rebuild probs
Re: Head light hole
« Reply #2 on: October 14, 2012, 03:49:02 PM »
+1
Offline Paul Lowe
Re: Head light hole
« Reply #3 on: October 14, 2012, 06:59:02 PM »
the rubber plug in it looks like it has never been used and I was tempted to make it a blinker indicator because i have been spoilt with modern auto blinkers and keep leaving them on!
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
Offline phil71
Re: Head light hole
« Reply #4 on: October 14, 2012, 09:44:11 PM »
Wait. Doesn't the cluster have a signal flasher in them?
Offline Paul Lowe
Re: Head light hole
« Reply #5 on: October 14, 2012, 10:04:47 PM »
yes but not very noticable...  maybe I just need to try harder... or a timer that beeps after so long...
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
Offline millerza
  • Zach Miller
Re: Head light hole
« Reply #6 on: October 15, 2012, 10:34:32 AM »
DO IT!
Re: Head light hole
« Reply #7 on: October 15, 2012, 10:43:57 AM »
i'm assuming  the same headlight can was used on other CB's where the indicator light was meant to go.
not needed on the 350Fs as the indicator is on the tree, so Honda plugged it.
you can wire in a switch for hazard lights there.
you could also wire in a mini LED and cover it with a cool gem.
tell everyone its your power crystal  ;D
« Last Edit: October 15, 2012, 10:55:54 AM by flybox1 »
Offline Paul Lowe
Re: Head light hole
« Reply #8 on: October 15, 2012, 12:49:34 PM »
Perhaps ejector seat or...
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
Offline chung
  • Giddy Up
    • chungfucycles.com
Re: Head light hole
« Reply #9 on: October 15, 2012, 05:09:20 PM »
The CB350K has no console between the gauges. It has a yellow and green light in the Tach and a red one in the top of the Headlamp.
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
