Author Topic: Widest rear tire?  (Read 2635 times)
Offline katmol
Widest rear tire?
« on: October 14, 2012, 01:36:55 PM »
I'm wanting to go with a wider rear tire. I was wondering if anyone has tried a 150/80-16 on a '77 Hondamatic.
'74 CB750K Tracy Project
'76 "Modified" GL1000
'77 CB750A Blue
'77 CB750A Red
'79 CM400A Hondamatic
'81 CM400A Hondamatic
"Gone but not forgoten."
'76 CB750A Muscat Green
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
'78 750K Black Dresser
Re: Widest rear tire?
« Reply #1 on: October 14, 2012, 04:14:35 PM »
The widest I have seen is a 330 on a K1...
http://forums.sohc4.net/index.php?topic=63553.0
« Reply #2 on: October 14, 2012, 09:00:14 PM »
Trust you to bring that one up again.... ;D
I am going to run a 160/60/18 on a 4.25 x18 rear rim, little bit of screwing around but doable... ;)
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #3 on: October 15, 2012, 12:43:56 AM »
I've ran the IRC Durotour in size 130/80/18 on several different 750s. They didn't offer it in a 140 or 150 but I'm 100% sure the 140 will clear and fairly confident that a 150 will fit. Of coarse sans chain guard. I really liked that tire so I never bothered to try a different brand. Who Knows what others might fit? I mean really, "Who Knows?" :-)
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #4 on: October 15, 2012, 01:01:22 AM »
P.S. I just looked and I have a CB750A with a 4.10x16 inch tire on it (aftermarket rim). It clears fine and has a 1/4 inch to spare at the chain so a 4.50 should clear and you might actually get a 4.60 on there?
Member#2815
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
« Reply #5 on: October 15, 2012, 01:19:28 AM »
As long as you are not trying to force them on stock sized rims they will fit...  You may need offset sprockets though...
Markcb750
« Reply #6 on: October 15, 2012, 03:24:49 AM »
Ha!  The same question I asked just after I joined in 2008, and the answer is still rim width & tire beads.
« Last Edit: October 15, 2012, 03:28:28 AM by Markcb750 »
« Reply #7 on: October 15, 2012, 04:54:59 AM »
Ah....tire beads.  That surely will get Retro's blood pumping!
« Reply #8 on: October 15, 2012, 09:47:26 AM »
 ;D
