Author Topic: head leaks on a cb550 75  (Read 2809 times)
Offline dergs713
« on: October 15, 2012, 05:56:58 PM »
bike runs strong but a small pool of oil shows up on the top fin on both sides for the head.  The oil is coming out of what looks for be pressed in pieces on the side of the head. three per side.  its a slow leak, but wondering how to fix this. any ideas.? will post pics if it will help.
Matt
Offline mono
  • Definitely no
Re: head leaks on a cb550 75
« Reply #1 on: October 15, 2012, 06:43:25 PM »
There are O-rings in there that you probably need to replace.
Sent from my SPH-L710 using Tapatalk 2
« Reply #2 on: October 15, 2012, 07:01:36 PM »
Post a pic of where the oil is pooling.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #3 on: October 15, 2012, 09:30:23 PM »
Welcome to my nightmare.
I and probably every other 550 owner is dealing with this.
There are oil return galleries on both ends of the head that have sealing issues.
I was told that new head gasket, o-rings and heavy duty studs are the answer, but I might go one further and install a little dowel as well.
Offline PrsCustom22j
  • "they've done studies you know...60% of the time it works every time"
« Reply #4 on: October 15, 2012, 09:44:26 PM »
welcome to the club!   8)
1976 Honda CB550K
« Reply #5 on: October 15, 2012, 11:20:41 PM »
Fun Jimmy those ain't oil return they are oil feed to the cam and rockers,
The leak at the sides could be either the "O" rings on the ond caps (2 each side) or the sealing washers on the bolt either side of the bracket the end cap fastenes to--possibly both
« Reply #6 on: October 16, 2012, 12:21:19 AM »
you wont need heavy duty studs.
Offline dergs713
« Reply #7 on: October 16, 2012, 10:10:11 AM »
its not coming from the oil covers. if that is what you are talking about this is a flush cover it looks to me on the side of the aluminum head itself.  it would have to be tapped or pressed out. will post pics of it later.
Matt
Offline dergs713
« Reply #8 on: October 16, 2012, 02:50:07 PM »
here are two pics after a couple days of ridding. my finger point to two of the three spots. hope this helps.Matt
Offline LesterPiglet
  • 1977 CB550F2
« Reply #9 on: October 16, 2012, 03:05:47 PM »
It can't be leaking from there. It's probably your alloy end caps, the oil is being blown around.
Offline dergs713
« Reply #10 on: October 16, 2012, 03:40:09 PM »
i guess that is an option, it really looks like its coming from there tho..
Matt
« Reply #11 on: October 16, 2012, 03:43:26 PM »
When the oil is everywhere it is hard to note it's source.  Clean it all off, and spray a supected area with foot powder.  Run the engine, and the wetted foot powder will show the oil leak source point.
Those end covers with the single cross head screw have o ring'd plugs for the rocker shafts.  Oil can leak there.
The cylinder cover has a seal around the perimeter that can leak oil.
The cylinder cover also has 6 oring "pucks" that can leak when they get hard.
The tappet adjuster caps have an oring that can leak.
The tach drive seal can leak, however it's at the other end of the cylinder cover.
If all the seals are as old as the bike's sell date, the rubber is likely pretty hard and reluctant to seal.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #12 on: October 16, 2012, 03:55:35 PM »
Good tip.
« Reply #13 on: October 16, 2012, 04:16:45 PM »
replace the alumium washers under the end cap bracket with new copper ones.
Offline dergs713
« Reply #14 on: October 16, 2012, 06:59:40 PM »
ok will give it a go on the next ride . thanks to all.Matt
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #15 on: October 16, 2012, 08:10:53 PM »
The good news is it doesn't look like your head gasket is leaking.Looks like you might have several leaks?  Buy a good quality top end gasket kit and take the breather cover and cam cover off and replace all the o-rings, pucks,  and gaskets. Don't forget the rubber band trick when installing the cam cover.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #16 on: October 16, 2012, 08:19:43 PM »
That or remove ALL the tappet adjusters until the cover is installed.
Offline dergs713
« Reply #17 on: October 17, 2012, 10:14:06 AM »
the prob is is that i just put this all together with the new kit...
this isnt my first rodeo, so thats why im confused. been working on motors for a while now. MAtt
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #18 on: October 17, 2012, 11:25:03 AM »
Then you must have missed something. A washer or o-ring or something didn't seat right.
Not necessary but backing them off is a good idea.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
