After seeing the white plugs, I raised the needles. I don't notice any extra heat. It idles slower, but seems to run just fine.
I was just really worried that using this gas, which has the ethanol plus an extra 50% cleaning agent, my plugs are so white.
If I continue to use it, should I leave the needles up?
Thanks
David
It may not hurt anything to run a little richer in the midrange (needles), but keep an eye on your exhausr pipes, right where they straighten out slightly after the first exit turn. If you run too rich, the fuel is still burning on the way out, and the pipes will start to turn blue or yellow. I don't know why the plugs would be white, but I don't know what the additive is in the gas that you're using, either.
