Author Topic: Oil filter adapter  (Read 2117 times)
Oil filter adapter
« on: October 15, 2012, 07:09:05 PM »
Hardly anything new invented here, just another run of the mill adapter.  I like Bosch and I built it to accommodate 3323 which is quite common in our neck of the woods.
« Last Edit: June 03, 2014, 03:49:35 AM by 70CB750 »
Re: Oil filter adapter
« Reply #1 on: October 15, 2012, 07:16:00 PM »
The nipple has M20x1.5 on both ends and screws in the engine block.  Next comes the aluminum plate with O-ring from CH6009 and the nut to hold the plate against the block.
I was lucky enough to find that nut - if I remember correctly it is from 1995 Ford Taurus front spindle and it has M20x1.5 thread too.  To turn the nut down was a bit of a challenge, but nothing the carbide insert would not do.  The nut has a collar that fits in the opening of the aluminum plate.
I wanted to make the nipple from a chunk of steel, but this time the scrap metal bucket under the lathe yielded piece of Corvette hollow steering bar 20mm in diameter.
« Last Edit: October 15, 2012, 07:18:33 PM by 70CB750 »
Offline 750resurrection
« Reply #2 on: October 15, 2012, 07:23:27 PM »
 Nice job. So it's just unscrew and replace ? Looks like it.  ;D
 Ooh I really like now.
 Oh one moment please...while I kick in mr angry negative ********... before someone else does.
 Ahh.. cb750 you must live in a bright neck of the crime free woods because a strong grip strolls by and your brand new filter is gone, your oil is on the tarmac, and you're stranded. I hope you have a Nike alarm, or a bike alarm.
 Not to mention, a good sized rock and it's right through that tin can bosch instant oil spray painter, and you're stranded on the highway that time.
 There is a reason Honda engineers decided in their vast wisdom to encase in strong metal...  >:(
( feel the hate, let it flow through you ! )
Gosh I hope no one else posted yet.
ps edit #2: You thought I was done ? Hardly!
 Have you done an oil pressure test before and after ? How about a flow test ? Have you checked cooling characterstics ? If you're into early engine damage ignore this.
(hahaha)  ;D Okay now all that is out of the way.
« Last Edit: October 15, 2012, 07:32:11 PM by 750resurrection »
« Reply #3 on: October 16, 2012, 03:19:33 AM »
You are not half bad at it :)
