Author Topic: Arduino powered carb sync gauge  (Read 7070 times)
Offline aperry
« on: October 16, 2012, 04:09:58 AM »
Stumbled across this last night:
http://www.instructables.com/id/Arduino-Throttle-Body-Syncronization-Shield/#step1
Does it save money?  Not really.  Is it more accurate?  Probably negligible.  Any easier to sync the carbs?  Doubt it.  But for those of us who enjoy the occasional geeky Arduino project it sure does look fun.  Add Bluetooth and batteries and you have a wireless self-contained monitor that talks to your laptop over the air.
Next up: how about the servo-controlled idle screw adjuster with a little dial controller mounted to the front?  Never again burn your fingers at a stop light trying to lower your idle :)
Aaron
CB750K3 with F1 frame/swingarm
Offline Blasbo
« Reply #1 on: October 16, 2012, 04:44:37 AM »
That is cool. I've been looking for an Arduino project.
Offline brewsky
Re: Arduino powered carb sync gauge
« Reply #2 on: October 16, 2012, 05:19:03 AM »
Far out!
Looks like he got to within 1kp or roughly 1/3 inch HG
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline cabrala
  • Super Duper
« Reply #3 on: October 16, 2012, 05:30:06 AM »
Man I'm liking this! I was just looking through my Arduino kit yesterday thinking about what to do...
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
Offline anders288
« Reply #4 on: October 16, 2012, 07:09:54 PM »
Group buy on some PC boards ? Any one able to do the PC software?
Offline CycleRanger
  • No comment about being an
« Reply #5 on: October 16, 2012, 07:33:56 PM »
Fascinating!
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #6 on: October 16, 2012, 07:34:41 PM »
Cool, nice compact device.  More compact than the old BMS system that I am thinking of using.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline cabrala
  • Super Duper
« Reply #7 on: October 16, 2012, 08:00:48 PM »
I've got a lot to learn, but I'd be up for a group buy. I'll also check to see what I have in my pile as there might be a few boards gathering dust.
-Alex
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Offline aperry
« Reply #8 on: October 16, 2012, 08:56:58 PM »
I'd also be in on a group buy, but I'm more of a tinkerer when it comes to Arduino.   I don't think I could take the lead on the design.  (Alternately I suppose we could contact that guy for his Eagle file).
When the bike is back indoors for the winter and I get bored enough, then I'll probably pull the trigger on those vacuum sensors and start playing around using a prototype board.  Would be fun to have one of these ready for a spring tune up.
Aaron
Offline Cabilao
  • Diving and Driving
    • Sea-Explorers Watersport
« Reply #9 on: October 17, 2012, 02:52:52 AM »
Nice idea but i stick with my gauges,im no electrician,no Sir.
before:
Kreidler RMC(50cc)
CB400N(first bike)
RD350LC(more than one)
XS850(great bike)
CB900F(wish i still have it)
FZR1000(too fast)
Rickman CR900(sold for a good price)
now:
Rusi 125
CB 125 CL(just for fun)
Yamaha XTZ 125
CB750P7(mystery bike)
77/78 cool 2 member
Offline aperry
« Reply #10 on: October 17, 2012, 09:05:01 AM »
I tried very expensive electronic manometers intended for industry and the analog gages adjusted easier. My electronic units are far superior to what is on the link. Four carbs hooked to a rack with pistons sucking them off is not a micrometer like precision task. You'll only get them so good and anything further is basically chasing your tail-but hey I'm one of those guys that likes to catch his tail fairly quickly rather than muck with it all night :)
I think that's a fair point.  In my opinion this would be more for the "gadgeteer" or tinkerer, than it is for solving a real problem.  But a lot of people find enjoyment in spending time building things that can be easily found in stores.  In fact, I'd wager this to be an overwhelming characteristic of members around here!!
Offline crazypj
  • I'm brill, me
« Reply #11 on: October 17, 2012, 09:13:50 AM »
Call me a Luddite, but, it seems rather pointless to me?
 I no longer have a cell phone, let alone a 'smart' phone  ::)
Offline stereosilence
  • 1975 CB550K
« Reply #12 on: October 17, 2012, 09:15:59 AM »
The software shouldn't be too difficult. The main thing would probably be dealing with hysteresis. I don't think you need to make your own PCB. You could just use a more generic PCB and a bit more soldering. I have several Arduinos laying around, the problem to me is that those vacuum sensors are $13 a pop.
Offline anders288
« Reply #13 on: October 17, 2012, 09:19:16 AM »
It's all about the software man
Offline aperry
« Reply #14 on: October 17, 2012, 10:36:52 AM »
Yeah, that's the killer.  Even if you already have an Arduino and proto board laying around, $56 for the sensors is a bit on the steep side if you're not really committed to the project.  I searched around for cheaper substitutes, but came up empty.
Btw, here's a thread where he talks about some of the challenges related to the sample rate and dealing with variations in pressure:
http://www.fjrforum.com/forum/index.php?showtopic=144773
  • 1975 CB550K
« Reply #15 on: October 17, 2012, 12:42:53 PM »
Sample rate shouldn't be a problem (depending on the capacitors). The capacitors should be from the sensor output to ground to from a crappy low pass filter. You could make the filter cut-off like 3 hz and then sample at 10 hz just to safe and you are off to the races. I don't have much experience with the arduino ADCs, but 10 hz would be SUPER slow for any ADC made since 1965. It would be better to use a low pass filter than to do the averaging in software anyway.
I think I would just write the output to a little dot-matrix screen rather than doing windows software.
Offline mono
  • Definitely no
« Reply #16 on: October 17, 2012, 01:10:21 PM »
that's some good stuff right there!   if i hadn't abandoned my Commodore 64 for a skateboard when i was a kid, i'd be doing stuff like this ;)
Offline WarwickE36
« Reply #17 on: October 17, 2012, 02:33:08 PM »
THIS IS SUPER NEAT.  Could care less about the functionality... might become a rainy day project regardless of cost.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline percolate
« Reply #18 on: October 17, 2012, 11:48:14 PM »
Super cool! Thanks for the link.
I want to try to build one of these! We (the extra geeky folks in the shop, not necessarily me) use Arduinos at work pretty often (interactive museum exhibits). I've gotten my feet wet a little bit but it's these types of home projects where I'm more willing to dive in over my head and muddle my way out and learn a bunch along the way.
Also, for a cheaper Arduino alternative, Adafruit sells a Boarduino - an Arduino clone if you will - for about half the price. You have to solder most of the parts onto the PCB but that's easy enough. And the prototypy PCB shields for the manometer may have to be laid out a bit differently to jive with the Boarduino chassis.
http://www.adafruit.com/products/91
Also, Processing is a pretty neat application based on the Arduino platform. Same C++ish programming and you can easily make a "dot matrix" output screen for the computer.
Looks like fun. :) And maybe I could make more than one...
The solution is painfully obvious once you know exactly what the problem is.
1976 CB550F - http://forums.sohc4.net/index.php?topic=118564.0
Offline davis96
« Reply #19 on: October 23, 2012, 06:44:46 AM »
Damn, realistically I'm not electronically inclined enough to do this, but this image really makes me want to try:
'74 CB350F - sold
'71 CB500K
Offline lucky
« Reply #20 on: October 23, 2012, 06:54:44 AM »
Heath kits came and went too just like this will.
You will see grocery carts full of them at the good will stores unfinished and incomplete of course and no one will know what to do with it except recycle it for the metal.
I only knew of one guy that ever completed a heath kit color TV.
Offline aperry
« Reply #21 on: October 23, 2012, 07:25:48 AM »
This isn't even a kit, so I don't think it would "come and go".  Before anyone even starts a project like this, they'd be required to source (and understand) the parts individually and have a basic understanding of how the Arduino platform works.  This is for the tinkerer or gadgeteer, not so much for practicality.  But the beauty of Arduino is that it's fun and easy to learn and it's modular so the same board can be easily re-purposed for lots of different projects.  You can do amazing things with it, including using it as a prototyping platform for a product that you may like to sell one day.  My first real Arduino project was a Sous Vide cooking machine, where the Arduino uses a relay and a temp sensor to keep a water bath at a very specific temperature.  It sent data to a small Linux computer, which plotted the temp/time chart to a web page.  I use it all the time and it's the best way to cook a pork tenderloin in my opinion!
I've continued to think about this project, and I'm tempted.  The following Kickstarter project also caught my eye (it's more about interfacing sensors with the iPhone/iPad):
http://www.kickstarter.com/projects/108684420/node-a-modular-handheld-powerhouse-of-sensors
This got me thinking about how you could make the whole project wireless and display it on a mobile phone/tablet.  You can buy a bluetooth 4.0 module for the Arduino for $35, which IMO would be the perfect way to make this project come alive.  The Arduino/sensor component monitors the vacuum, and the iPad/iPhone displays the graphs.  Of course, it's $150 in hardware (not counting the tablet!) and several hours of time, so it's not for everyone.  But IMO there's something fun about bringing 2012 technology to a vintage motorcycle.
I've also enjoyed reading about the RFID ignition switch.  So many fun projects, so little time (and money).
Aaron
