Author Topic: 77-78 CB750 F2-F3 Reproduction carb boots and other Honda rubber bits!  (Read 11583 times)
Offline kmb69
They seem to seal well but while I was synching the carbs I observed that the boots are so soft, that you could actually see them pulsating with each induction cycle.
The very early 69 and 70 boots (short spigot heads) had a much thinner wall section and you could see them pulsating big time to the extent that the carbs would move. Never heard of any leaking though until they got hard and crusty. They were beefed up considerably with the -305 revision.
Offline MarshallCS
  • The Audio Ninja
  • The things I can control are in control
Just curious, but why are these made out of rubber? Wouldn't a set of aluminum, or some type of metal work just as well without the deformation or the burning up the rubber ones have?
First and Only Bike
1978 Honda CB750F Supersport
Offline Bailgang
  • Scott
  • Indiana
Pure speculation but I would imagine the primary reason the boots are rubber rather than a direct metal to metal contact is because the rubber acts as a heat insulator, without some sort of heat insulating material between the cyl head and carbs then all the heat from the cyl head would transfer to the carbs. I'm just guessing though.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
