Author Topic: 1978 CB550K Stripped  (Read 31097 times)
Offline ampsrampstramps
    • 14SF
Re: 1978 CB550K Stripped
« Reply #50 on: January 08, 2013, 10:21:49 PM »
I don't know. Is this good or bad? It's not brownish but is grey.
When I ride, maybe because it is cold right now, there is a white smoke that is pretty constant even after the bike is fully warmed up.
It kinda smells like gas but not really. It doesn't really match up with any spark plug diagram I can find.
Crush, got the PM. Stuff is here if you want it.
"When you've got them by the balls, their hearts and minds will follow." - John Wayne
1978 CB550K / 1980 CB750F / 1973 CB450 DOHC / 1975 TL250 / '82 FT500 / '78 SR500 / '92 XT600
Offline iron_worker
« Reply #51 on: January 09, 2013, 06:11:48 AM »
Looks like it may be lean. However the part that really matters is where the ceramic meats the base of the plug (the threads are shielding it). You may need a flashlight to look down to the bottom of the ceramic.
IW
    • 14SF
« Reply #52 on: January 11, 2013, 08:47:09 AM »
IW
Thanks. I will have another look and report back.
Offline cabrala
  • Super Duper
« Reply #53 on: January 13, 2013, 05:13:33 AM »
PM and email sent to finally take the stuff off your hands. Thanks, Nick.
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
    • 14SF
« Reply #54 on: January 21, 2013, 10:14:39 PM »
HEADLIGHT
Got a new headlight. Hella 500 Black Magic driving light from Pepboys. 12v/55w. Hoping it works out. Hooked it up to the HI beam wire so it's only on when I flick the HI switch and it's off in the LO setting. Got all of the wiring out of the old headlight, chopped most of it off and put the rest under the tank. Still working that out. It's a mess. The break line needs to be sorted also. Runs right through the middle where the headlight goes. Probably going to remove the break light switch and just run an unbroken line down to the front brake.
Here's the bracket. Bolts in where there used to be a bracket holding the wiring harness.
Because the future is Hella bright.
« Last Edit: January 22, 2013, 08:19:24 PM by ampsrampstramps »
« Reply #55 on: January 25, 2013, 04:21:09 PM »
Looks Hella Good.  Cool looking light!
    • 14SF
« Reply #56 on: January 29, 2013, 08:58:33 PM »
Thanks! Just a few more things and it should be done.
Offline SF
  • I burn gas very well
« Reply #57 on: January 30, 2013, 11:50:18 AM »
+1
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline stuartni
« Reply #58 on: February 04, 2013, 03:55:25 AM »
love this build bike looks amazing
    • 14SF
« Reply #59 on: February 14, 2013, 09:40:50 PM »
I got a powder coat gun and a toaster oven. It's super cheap, super easy and the results are super good. Here's the first test run. It worked out so looking into other oven options.
« Last Edit: February 15, 2013, 04:51:20 PM by ampsrampstramps »
Offline SF
« Reply #60 on: February 15, 2013, 10:01:03 AM »
realy like the flat black pc. you going with that for the hole bike?
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
Offline Vinhead1957
« Reply #61 on: February 15, 2013, 01:09:21 PM »
Where did you get the powder coat kit the results are impressive
    • 14SF
« Reply #62 on: February 15, 2013, 04:24:02 PM »
I ordered it from Eastwood. Just hook it up to the compressor and go.
Not at the moment. Trying to work out a way to fit the frame in a toaster oven.
    • 14SF
« Reply #63 on: January 05, 2014, 06:29:52 PM »
Painted the wheels black. Just what it needed.
The size of the tank was making the bike look anorexic. I held up the stock side covers and it looked good. Gave it a bit more girth. So having detabbed the frame I started to try and make some new ones out of metal.
But in the mean time I put some tabs back on and popped the stock covers in.
Looks good in photos but if you saw it in person the covers don't sit perfect, on top of being plastic. The new ones will probably bulge out from within the frame triangle. I'll just hinge it and either put the stock air box back in or add a box down there for a trunk.
Offline KPD
« Reply #64 on: January 11, 2014, 11:13:29 PM »
Great build!! I have a '78 550 that I'm starting now, what tires are those?
    • 14SF
« Reply #65 on: January 12, 2014, 12:50:32 PM »
Shinko 705
Rear is 120/80
Front is 110/80
But they were way narrower and thinner than the size would suggest. I'd get 140 in the back and 120 in the front if they have it.
« Last Edit: January 18, 2014, 09:41:26 AM by ampsrampstramps »
Offline jason405
« Reply #66 on: January 20, 2014, 08:41:41 PM »
Hey man, just curious about what process you used to paint your wheels? Did you disassemble? Blast first? What paint, etc.
Wanting to do this to my 550k eventually.
Thanks!
Jason
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #67 on: January 21, 2014, 09:18:52 AM »
Im really liking what your doing here. Giving lots of ideas for my 550 build.
How's that Dyna Ignition system treating you? I always read mixed reviews about it.
I do tasks the most difficult way. My life is interesting.
1978 750K
1978 550K on a table
2009 Ducati Monster 1100
77/78 cool 2 member
    • 14SF
« Reply #68 on: January 23, 2014, 09:46:17 PM »
Well. I just hit them with rattle can wheel paint. Nothing crazy.
Thanks!
Jason
    • 14SF
« Reply #69 on: January 23, 2014, 09:50:44 PM »
Thanks. The ignition and coils are great. Though I can't say much about how it ran before I put them in because I only had it for a week.
    • 14SF
« Reply #70 on: December 09, 2014, 04:49:33 PM »
Final pics. Should enlarge when you click.
« Last Edit: December 09, 2014, 04:55:18 PM by ampsrampstramps »
Offline Restoration Fan
  • My wife will never call me
« Reply #71 on: December 09, 2014, 04:57:36 PM »
Beautiful bike.  Any plans to put fenders on it or just going to leave them like that?  I ask because I would think it would suck to ride it on a wet road without fenders?
Offline Slinky
« Reply #72 on: December 13, 2014, 08:35:50 AM »
what length Renthal bars did you use??
    • 14SF
« Reply #73 on: December 13, 2014, 10:19:02 AM »
Renthal 7/8" Road Low - Not sure what the length is. Only come in one size as far as I know.
No plan for fenders. Agreed. Riding in the rain sucks with or without fenders.
Offline Tews19
  • I am no
« Reply #74 on: December 17, 2014, 04:54:43 PM »
I saw it listed on ebay. Good luck on the sale.
1970 Honda CB750 survivor.
