Author Topic: Why are the foot pegs offset on a 750??  (Read 7205 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: October 22, 2012, 09:36:41 PM »
The right one is several inches farther forward than the left.
Why'd they do that??
Offline rhinoracer
Re: Why are the foot pegs offset on a 750??
« Reply #1 on: October 22, 2012, 09:46:13 PM »
I don't know the reason but I cut the longer one to match the other. Haven't run into problems yet as I haven't finished putting the bike together but I found it odd too.
Baja native.
Offline lucky
« Reply #2 on: October 23, 2012, 06:57:18 AM »
It is simple . The right peg is different to accommodate the kick starter.
But the bottom line is... some people just cannot stand anything that is not symetrical.
Offline rhinoracer
« Reply #3 on: October 23, 2012, 08:05:21 AM »
So true, some sick minds even go to extremes as to cut and weld foot pegs to make them match.  :-[
Baja native.
« Reply #4 on: October 23, 2012, 08:23:46 AM »
You mean the left one is not the same as the right one?    ;)
Offline mrrch
« Reply #5 on: October 23, 2012, 08:53:05 AM »
The mounting bracket should be rotated towards the rear. Several inches?? Might be rotated forward on the mounting bolt or has the wrong mount.
my build
« Reply #6 on: October 23, 2012, 09:05:21 AM »
It's more like an inch+. Its a design compromise on both sides IMO. On the right, the KS doesn't foul the peg (or vv) until the KS is near the end of its stroke. Not such a big deal.
So that side could've been shorter to match the left. I think the right side being slightly forward is as much an ergonomic decision to achieve a good angle on the brake pedal.
On the left side though, the peg can't be anywhere else as the engine is in the way.
The mounting brackets can't really be rotated to achieve any other combo as they have locators that need to be engaged for safety.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #7 on: October 23, 2012, 10:13:19 AM »
I'm pretty sure my 78' 750K and 750F are symetrical. A lack of symetry here would likely be bothersome for me. You sure the pegs aren't rotated out of position?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #8 on: October 23, 2012, 10:27:40 AM »
I was wondering about that on the later bikes. But on the K2+ models the pegs are definitely offset and should not be rotated to try and fix it. It is just that way. Older BMWs were too, as one cylinder is farther ahead of the other.
Offline gecko672
« Reply #9 on: October 23, 2012, 12:51:58 PM »
My k1 has the offset foot pegs. Its an inch maybe 2 max, just enough to visually notice. I always wondered about it, but now I know its not just me.
CB750 1971 K1
Offline Magilla
  • My bike: 1976 CB750F
« Reply #10 on: October 23, 2012, 02:03:48 PM »
The pegs on my K6 are offset.  I thought I was drunk the first time I noticed it.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
bollingball
« Reply #11 on: October 23, 2012, 04:54:04 PM »
I had to go look. My right peg is 3/8th'' forward of the left measuring off the center of the swingarm bolt. 78 K. It could be bent. Never would have noticed it if not for this post damn it.
Ken
Offline hondaface75
« Reply #12 on: October 23, 2012, 05:27:02 PM »
The kickstarter on my 77K was different than my 75K. Its got a sweep to it at the start. Maybe they desided to change the KS instead of the pegs later down the road.
« Reply #13 on: October 23, 2012, 08:01:36 PM »
 No, they changed the pipes, kicker has to clear them....
 Only one of the many parts for 77/78, that are thicker, wider, heavier..
Offline ncstatecamp
« Reply #14 on: October 23, 2012, 08:15:58 PM »
Just to prove it....
I'm also glad this was posted bc on my reassembly I thought I #$%*ed something up...
Offline cb650
« Reply #15 on: October 23, 2012, 08:56:00 PM »
Why is the posts not centered?
Offline ncstatecamp
« Reply #16 on: October 23, 2012, 09:03:18 PM »
which post?
« Reply #17 on: October 23, 2012, 09:10:43 PM »
The left peg is just about the only place it can be due to the engine cover. It is nearly directly above the motor mount it is attached to. Slightly forward.
The rt peg is also above the MM, but also slightly forward, but moreso. The reason is pure speculation. Some say to clear the KS or vv. It doesn't seem to me to be the reason. Seems more to me that Honda in theiir infinite wisdom was looking for the ideal place to put the average size American foot in relation to the brake pedal. The pedal's length also being an engineering decision to reach an optimum leverage.
I've read that Honda puts a lot of effort into these ergonomic decisions. As this thread indicates, most owners would never even notice until something points it out to them. Same with me, I remember the first time i realized it and said "my, my"..
OCICBW
« Reply #18 on: October 23, 2012, 09:41:38 PM »
I was checking and noticed my feet were offset too. Hmm.
« Reply #19 on: October 23, 2012, 10:01:49 PM »
Yeah, my left one is bigger, so it works out for me!
« Reply #20 on: October 24, 2012, 07:10:52 AM »
 I am surprised how many of you never noticed...
« Reply #21 on: October 24, 2012, 12:23:45 PM »
lol...I never noticed.  I now have a cb750 with rearsets which are not offset...but it feels like they are!
Offline Gordon
  • 750K1, 550K2
« Reply #22 on: October 24, 2012, 12:38:13 PM »
If the horizontal offset bothers you, don't go measuring the vertical. ;D
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #23 on: October 24, 2012, 01:36:21 PM »
+ 1 I'm surprised it hasn't been mentioned in this thread.  :)
Offline lucky
« Reply #24 on: October 24, 2012, 02:57:59 PM »
On one custom bike I built the right foot rest needed to be 1 inch higher on one side. No one ever noticed and it felt normal.
